83 d350 crew cab drive train swap
Old 12-31-2017, 07:10 AM
Pmschmitt's Avatar
You are correct I have not located a fan shroud. Seems to have been lost somewhere in the shuffle. May have to source one
Old 12-31-2017, 08:02 AM
Received 1,637 Likes on 1,112 Posts
Holy roof rust, Batman !
Nice score(s)
Old 12-31-2017, 08:28 AM
Pmschmitt's Avatar
Firing off donor truck
ok so may be a weird question, but I am trying to get the donor truck cummins to fire off before pulling it from the truck. I have a video of it running 1 month ago, but I have not personally heard it.
The fuel tank tank has been dropped by PO. there is a fuel line running from the fuel primer. I placed the fuel line in a fresh can of diesel and primed it by hand. Didn’t fire. I cracked the fuel lines on 6,4,2. Lots of air then fuel. Still wouldn’t fire. Cracked the injectors at 1,3,5. Lots of air then fuel. Still wouldn’t fire. The fuel coming in seems to have a lot of foam/ bubbles. Still may have air getting in somewhere. The battery finally gave out so I put it back in the charger to try again today.
Is is there any other thoughts you guys have. I know it can take a long time to get the air out of these lines sometimes. Thanks
Old 12-31-2017, 08:38 AM
Received 2,394 Likes on 1,577 Posts
Are you opening up the FSS using a hot wire, or is the truck wiring still doing it?
Bleed the air from the top of the fuel filter housing first, then work to the lines.
Old 12-31-2017, 01:48 PM
Pmschmitt's Avatar
FSS still hooked up to wiring. I believe it is activated bc fuel is coming through the injector lines. I am gonna bleed it at the fuel filter and try it again. I’ll keep y’all up to date
Old 12-31-2017, 02:33 PM
Pmschmitt's Avatar
I'm gonna move this thread over to the cummins conversion section under 1983 crew d350 CTD 5 speed
92betsy
05-29-2017 11:01 PM
fratzog
1st Gen All Products
0
05-10-2015 09:42 PM
bryson711
06-25-2011 08:48 AM
Firebb15
Cummins Conversions
02-25-2010 03:59 PM
Banzai Bob
03-03-2009 01:22 AM
Quick Reply: 83 d350 crew cab drive train swap
