83 d350 crew cab drive train swap - Page 2 - Dodge Diesel - Diesel Truck Resource Forums
Thread Tools Search this Thread
Old 12-31-2017, 08:10 AM   #16
You are correct I have not located a fan shroud. Seems to have been lost somewhere in the shuffle. May have to source one
Pmschmitt is offline   Reply With Quote
Old 12-31-2017, 09:02 AM   #17
Holy roof rust, Batman !
Nice score(s)
NJTman is offline   Reply With Quote
Old 12-31-2017, 09:28 AM   #18
Firing off donor truck
ok so may be a weird question, but I am trying to get the donor truck cummins to fire off before pulling it from the truck. I have a video of it running 1 month ago, but I have not personally heard it.
The fuel tank tank has been dropped by PO. there is a fuel line running from the fuel primer. I placed the fuel line in a fresh can of diesel and primed it by hand. Didn’t fire. I cracked the fuel lines on 6,4,2. Lots of air then fuel. Still wouldn’t fire. Cracked the injectors at 1,3,5. Lots of air then fuel. Still wouldn’t fire. The fuel coming in seems to have a lot of foam/ bubbles. Still may have air getting in somewhere. The battery finally gave out so I put it back in the charger to try again today.
Is is there any other thoughts you guys have. I know it can take a long time to get the air out of these lines sometimes. Thanks
Old 12-31-2017, 09:38 AM   #19
Are you opening up the FSS using a hot wire, or is the truck wiring still doing it?
Bleed the air from the top of the fuel filter housing first, then work to the lines.
oliver foster is offline   Reply With Quote
Old 12-31-2017, 02:48 PM   #20
FSS still hooked up to wiring. I believe it is activated bc fuel is coming through the injector lines. I am gonna bleed it at the fuel filter and try it again. I’ll keep y’all up to date
Old 12-31-2017, 03:33 PM   #21
I'm gonna move this thread over to the cummins conversion section under 1983 crew d350 CTD 5 speed
Thread Thread Starter Forum Replies Last Post
1985 d350 vs 1992 d350 92betsy 1st Gen. Ram - All Topics 6 05-30-2017 12:01 AM
Truck For Sale 1985/1993 Dodge D350 Cummins CREW CAB with 4x4 conversion fratzog 1st Gen All Products 0 05-10-2015 10:42 PM
81 to 93 crew cab swap bryson711 1st Gen. Ram - All Topics 14 06-25-2011 09:48 AM
85 crew cab cummins swap? Firebb15 Cummins Conversions 2 02-25-2010 04:59 PM
Crew Cab 6x6 (Post your Crew Cab Pics) Banzai Bob 1st Gen. Ram - All Topics 10 03-03-2009 02:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright 2017, DieselTruckResource.com We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
