5 speed: Noisy Third Gear
Old Aug 6, 2007 | 08:45 AM
markm4's Avatar
Since I got the mud tires off, I can hear my engine and drivetrain better, and I can clearly hear my transmission/drivetrain at different times, mostly when accelerating. It sounds like "gears", sometime maybe kind of like clanging or ringing too.
Especially in third gear, when accelerating, and put the power to it.
Is this normal?
Mark
Old Aug 6, 2007 | 10:29 AM
TonyB's Avatar
Have you checked the fluid level? When was the last time it was changes? Does it sound like gears meshing or a bearing whine?
Tony
Old Aug 6, 2007 | 11:29 AM
Baja's Avatar
First, fill out your signature so we know more about your truck, makes it easier
I had a "noisy third gear" too when I first got the truck. I changed the oil a few times and it behaved OK. This lasted about 10,000 miles. On a normal routine shift from 2ed to 3rd, the trans started to make a very bad sound. I dropped a tooth. Not by choice I now have new trans with upgraded 5th gear. My mechanic pointed out how third gear is on the weakest part of the shaft, in the middle, as far from supporting bearings as you can get. This gear also probably takes the most abuse, tons of torque going through it during hard acceleration. This is not to say that you will experience a trans failure as I have, but I can say that third gear could be problematic. Change the oil and keep a ear on it.
Old Aug 6, 2007 | 11:31 AM
markm4's Avatar
5 Speed
Sounds more like gears meshing.
I have had the truck about 3 weeks now, but have not checked the manual transmission fluid level yet. There is a plug on the passengers side with a metal tag on it that looks like it might be the place to add fluid. It is about 2/3 of the way up on the unit from the bottom. What I do not see is a plug near the bottom to drain the fluid, so I can change it.
Mark
Old Aug 6, 2007 | 11:53 AM
SPLnut's Avatar
the plug about 1/2 up the trans on pass side is the fill hole and takes a 3/8 allen wrench and drain through the pto bolts (if i can remember correctly)
Old Aug 6, 2007 | 01:37 PM
markm4's Avatar
Thanks, I'll check it tonight. Where do I get this lovely fluid from? I hope it helps.
Old Aug 6, 2007 | 01:53 PM
SPLnut's Avatar
Dodge or a gm dealer (High dollar) unless you go for Amsoil synthetics (heard it works great and is cheaper then dealer stuff)
Old Aug 6, 2007 | 02:56 PM
markm4's Avatar
can I top it off with AMSOIL or do I have to do a complete change.
Thanks
Mark
Old Aug 6, 2007 | 07:07 PM
SPLnut's Avatar
Wouldn't hurt to change it completely...I'm about to do the same...
Old Aug 6, 2007 | 07:53 PM
300sd2500's Avatar
You need 4 quarts. Amsoil runs about $9.00 a quart and the syntorque from dodge runs about $18.00 a quart.Not many fluids are gl-4 rated.
Alot of people say to only use the syntorque, because of the sychros being carbon fiber. I am using the Amsoil now, but I need to do a change and I am going with the syntorque.
You can also get the syntorque from quad4x4 for I think $54 for a gallon.
Old Aug 6, 2007 | 11:28 PM
RFR2212's Avatar
I've got a similar problem in my truck. When ya get on to it till about 1500 sounds like a good howl/vibration sound. Above 1500 it sounds the exact same. This only occured after I installed the new clutch in the truck. Shifts seem as smooth as ever and only had a small grinding noise at at idle with the trans in neutral and no the clutch engaged (just sitting, not disengaged so to speak.) I have no clue what this problem may be. For the most part that idle "grind" has lessened alot with more milage on the new truck. SBC thought it may be the imput bearing on the transmission...
I don't know..
onesourceoil
Feb 4, 2005 08:02 AM
appydriver
Dec 7, 2004 05:03 PM
FastSS
16
Mar 8, 2004 09:13 PM
tool
Feb 26, 2004 02:30 PM
tool
Feb 15, 2004 09:33 PM
