need help, truck idling 2500rpm+
Old Jul 17, 2007 | 06:42 PM
blownsmok97's Avatar
just yesterday i was driving home and pulled to a red light and my truck just started idling at about 2500 rpm or more. i shut it off then started back up and it jumped straight up to 2500 again.
i checked the idle adjust screw but nothin. i wonder if anyone has any ideas or anything of what could be wrong. any help will be greatly appreciated.. thanks a bunch
Old Jul 17, 2007 | 06:45 PM
clutch1's Avatar
was the trottle linkage hung up maybe, or does it graduall climb in rpm once you start it? is it still doing it?
Old Jul 17, 2007 | 07:10 PM
i looked at the linkage and didn't see it hung up anywhere, so it isn't that i know of, and it is still doing it. i woke up this morning and tried it and it's doin the same still.
the rpms don't instantly shoot up but gradually do pretty quick though. they climb up in just a matter of a few seconds.
Old Jul 17, 2007 | 08:07 PM
clutch1's Avatar
if its not an external prob with the linkage its something internal with the fuel rack sticking.
Old Jul 17, 2007 | 09:26 PM
Box5's Avatar
did the throttle spring break?
Old Jul 17, 2007 | 11:19 PM
Ponci's Avatar
Either a stuck rack or the govenor is hanging up.
Old Jul 18, 2007 | 06:36 PM
i don't think the spring broke it looked good to me.
how do i check if the rack is sticking? how can i fix it? how can i check the governor?
Old Jul 18, 2007 | 09:31 PM
kawi600's Avatar
pull the afc off and move the throttle linkage around with the fuel cutoff solenoid pulled up. Should see the governor lever arm moving smoothly to contact the bottom of the fuel plate. Did you do the GSK recently? Maybe look and make sure none of those studs are damaged? Otherwise its to an injection shop it goes Id say.
If you have a C02 fire extinguisher handy Id keep it in the truck just in case it sticks and wont shut off. Scary.
Old Jul 18, 2007 | 11:15 PM
k ill check that in the morning when theres some light. i did the gsk about 5 or 6 months ago i think, so it's been a little while. no problems with that til now.
i haven't been driving it for that reason, having the fuel stick wide open drivin around just don't thrill me very much
Old Jul 19, 2007 | 10:51 PM
dieseldemon's Avatar
Sounds like its external I had one with a stuck rack internaly and I could not shut it off with the key pulled the pump and put it on the machine they told me the rack was stuck fixed it for $100.00 been ok for the last 70000 miles
Old Jul 20, 2007 | 09:54 AM
i checked the gov arm today, it seems to be fine, still contacting the plate in the same spot on bottom, seems to be ok, but what exactly would it do if its sticking?
what should i check externally on it?
Old Jul 20, 2007 | 10:24 AM
clutch1's Avatar
make sure everything is in the idle position, make sure linkage is not hitting anything. if you start it and it goes to 2500rpm what does the throttle to? can you push on the pedel and tell a difference?
Old Jul 20, 2007 | 11:03 AM
Baja's Avatar
There is a throttle cable recall on these trucks, #970 if I remember right. Call the dealer and see if your truck has had the work performed. Mine was very frayed when I saw it after they had removed it.
Old Jul 21, 2007 | 11:24 AM
rainfade's Avatar
Could you simply pop the linkage off the pump and fire it up see if the idle is normal or high then you'd know if it's somewhere in the cable/bellcrank/linkage or a bigger problem.
Just a thought.
Old Jul 23, 2007 | 10:15 PM
doodah's Avatar
also, I see you are running a 3K gsk, is it the washers? or is it the real deal with the springs???
if its the washers, might be hanging up or catching in the springs and couasing your idle to stay high on the idle spring.......
