12v to 24v swap
Old Dec 13, 2006 | 09:39 PM
bettencourtraci's Avatar
12v to 24v swap
i was wondering if any one has done a swap frome a 12v to a 24v in the early 90's pickups thank you
Old Dec 14, 2006 | 05:45 AM
Txwelder's Avatar
Nobody in their right mind has, not without converting the 24 valve to a P-pump.
Old Dec 14, 2006 | 06:22 AM
CTD NUT's Avatar
What he said.....
Stock to stock, the 24v head will flow somewhat better but not enough to be concerned about. And the VE pump is still more reliable than the VP44. If you are talking about the 94 and later 12v pump, Dodge never put a better pump on the CTD than that so you would truly be nuts to swap it out.
Old Dec 14, 2006 | 09:09 AM
~Angry Tractor~'s Avatar
I think if I had a spare Cummins layin around I'd drop it in a Ford and not have to deal with all the front end and transmission/transfer case, AC, etc. etc. problems my truck is plagued with.
Old Dec 14, 2006 | 07:14 PM
was just wondering because i have an 01 com pleat donner truck with a six speed with 80000 miles and my old truck has 280000 miles
Old Dec 14, 2006 | 09:53 PM
Lunyfringe's Avatar
mine's at about 275k, and still going strong... I wouldn't be concerned at all with mileage under 400k (the mean time to rebuild for the Cummins) sell the '01 engine to someone that needs a 24v, and use the $$ to upgrade your truck...
Old Dec 14, 2006 | 10:38 PM
torquefan's Avatar
I think it would be a pretty cool project. However, if I had an extra 5.9 laying around, I'd look for a nice Superduty Lariat with a blown-up 6 litre to put it in. (just to be different.)
Old Dec 15, 2006 | 06:46 AM
CTD NUT's Avatar
Not sure what truck you have (fill out your signature) but if it has a P pump, whatever you do, make sure you retain it if you decide to use the 24v engine.....do NOT attempt to swap in the VP44 and its associated electronic engine management system.....that is really taking a step backwards. And even if you had a 1st gen with the VE, I still think it would be a bad idea to attempt to convert it to a VP44.
You can use the 24v engine, but keep your existing mechanical pump!
At this point, I do agree with torquefan, sell the 24v and use the $$ to freshen up your engine....makes much more sense and would be less work and you will get more bang for the buck that way too.
STACKED
14
Oct 5, 2010 03:08 PM
CmminsBeast
Aug 21, 2007 07:24 PM
getblown5.9
May 20, 2007 04:25 PM
bettencourtraci
Dec 14, 2006 06:47 AM
TireHauler04
Apr 10, 2006 06:24 AM
