12 valve getting no fuel
Hi yall. My 96 CTD 3500 4X4 Dually died the other day getting no fuel I replaced the obvious filters and such after no fix got deeper then replaced the lift pump with the good onie and still no luck then blew all lines out with air hose did have trash in the fuel replaced filters again cleaned the screen on separater replaced filters bleed all lines proper and still nothing someone told me dodges bad for fuel lines rusting into inside the tank ? Anyone have any ideas? THANK YOU FOR YOUR Time. CROSSTHREAD
Sorry I haven't been back on here my pc at home died. Couple of guys told me I should invest in an aftermarket electric fuel pump dual filter system I agree. Does anyone have a good experience with a certain brand? My guess is to replace fuel lines and install a fuel pump system and drive it another 300, 000 miles! !! Thanks for any help. Wayne in Salem, Missouri
Sorry, I see absolutely zero reason for removing a stone cold reliable mechanical pump that will support up to 600 Hp with an electronic unit, none of which seem to last as long as our piston pumps do................. I say, replace the lines from the tank all the way to the engine with diesel rated rubber, make sure your module steel lines aren't rotted, and drive in peace......not worrying your fancy electric pump is going to die and leave you by the side of the road.
Cummins Guru
First off where are you checking for fuel pressure?? No fuel at the injectors or at the fuel supply line to the injection pump? Are you sure the fuel solenoid valve is lifting up if no fuel pressure at the injectors? If no fuel at injection pump did you clean the screen in the preheater?
Fuel lines are sucking wind. The braided lines that go over the transmission bell housing begin to leak inside the braid and at the connectors. Best fix is to run new marine grade diesel lines from the tank to the engine. I have just replace the lines from the hard lines on the frame up but the lines from the tank to the frame leak too. Even if it's not the sole problem, it's a must do for your CTD. You can hear a ticking sound in between the cab and bed and if you lay under the truck the braided lines will pulse and sometimes you'll see moisture around them. While you're at it change the overflow valve if you already haven't. Also make sure you're fuel shutoff valve is working properly, might check that first. Order a new one with the overflow from Larry B's. Good luck.
JBradley500
05-24-2011 08:50 PM
M Penwald
14
03-26-2011 08:41 PM
GLHS
10-01-2006 10:20 AM
getarealjob
08-29-2006 10:16 PM
