#10 plate and stock clutch?
Old Dec 28, 2002 | 10:30 AM
dsljunkie's Avatar
Is it possible to run a #10 plate with a stock clutch with 115,000 miles or will it slip too much? If so then how about a #11?
Old Dec 28, 2002 | 11:35 AM
gitchesum's Avatar
Re:#10 plate and stock clutch?
I couldn't run the stock clutch with my #10 plate. When I added the 370's, I could slip the clutch in 3rd through 5th gears.<br>You might get away with the #11 plate. But at 115,000 miles it might be time to replace the stocker anyways, might as well go for the SBC Con OFE. Smoother than stock and holds great.
Old Dec 28, 2002 | 07:01 PM
oldred97's Avatar
I have a number 10 plate and 370's with a stock clutch. It worked for a while but it isn't by all means gonna last because mine too is now slipping 3rd through 5th.
Old Dec 29, 2002 | 11:41 PM
dodgeman01's Avatar
I had the #10 and 300inj installed all at once. my clutch with 90k held for about a year before it would slip.<br>DM01
Old Dec 30, 2002 | 08:51 AM
atc250r's Avatar
I am running a #11 plate all the way foward the stock clutch with under 30,000 miles began slipping as 3rd through 5th (mostly 4th &amp; 5th) as soon as I put it in. I haven't done any other mods except what's in my signature. I haven't even put a trailer on it and it will not hold. I am going with a South Bend Clutch as soon as the tax return comes. Drop them a line, they answer your questions quickly and will not try to sell you the most expensive clutch, they'll sell you the RIGHT clutch for your truck.<br><br>John<br><br>
Ken Collins
13
Aug 20, 2010 10:54 PM
plow
Jul 20, 2005 08:40 PM
Rockcrawler
14
Jun 23, 2005 11:40 AM
banks twinram
Feb 5, 2005 10:38 AM
cummingetit
16
May 17, 2003 03:38 PM
