Tuning and gauges
Old 02-08-2016, 08:05 PM
I think I can... I think...
capt.Ron's Avatar
Tuning and gauges
Looking to do an EFI live tune on my 2010 mega. The unit sold by the vendor/tuner I'm talking to doesn't have a gauge readout. They are recommending me buying an edge from them along with. This is going to drive up my cost of tune/tuner/and edge (a tuner as well?) to somewhere close to 1800 bucks! YIKES!!!!
What are you guys running EFI live tunes doing to monitor EGT, Boost and Trans temp? What other things would you find important? Fuel pressure, others?
Old 02-09-2016, 04:53 PM
Busboy's Avatar
Look for a used mini maxx it will do gauges as well as provide defueling for EGT, boost, coolant temp and trans temp.
Old 02-11-2016, 08:31 AM
Mcmopar's Avatar
EFI Live is very impressive on these trucks. I've tuned a few and the results are awesome. You are correct, no gauges. Install an A pillar pod with gauges.
Old 02-11-2016, 03:10 PM
capt.Ron's Avatar
Is there a way to connect up via OBDII or the ecm to get trans temp and boost? I think that's one of the pluses to using a tuner that has readouts. I just don't want to have to by the EFI Live and then a completely separate tuner.
Old 02-11-2016, 04:02 PM
Mcmopar's Avatar
If I'm not mistaken, you HAVE to buy a Bully dog and the optional "unlock" cable to "free" the Dodge ECM so you can install the EFI Live program. I am 100% positive you have to on the 2014 and up trucks, but am not positive when that started. I recently did a 2006, and no unlock was required. May I ask who is writing the tune for you and are you using the 4 position switch to control your power settings? Also, if you have an auto, be 100% sure whoever is writing your tune also address the tranny or.....it will get very expensive very quickly!
Old 02-11-2016, 04:28 PM
capt.Ron's Avatar
I'm looking at Anarchy. They didn't mention needing bullydog to unlock. I was going to have to buy their tuner. Think it's branded "Mercenary"
and yes I'll get the switch and transmission tuning as well.
Old 02-12-2016, 09:05 AM
Mcmopar's Avatar
Before you pull the trigger call Jonathan at Higher Power Performance. He is fantastic to deal with and his programs are awesome.
HIGHER POWER PERFORMANCE
2079 EDWARD WILLIAMS RD
Gadsden, TN 38337
731-410-7200
Kman9090
29
12-06-2007 06:43 PM
coontz0473
17
09-22-2006 03:52 PM
Duckman1993
09-12-2006 07:50 PM
abc4yew
13
07-28-2006 09:47 AM
Katmandu
02-13-2006 04:38 PM
Quick Reply: Tuning and gauges
