4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Front end drive issue after 4wd use...
Old 03-22-2017, 06:43 AM
xp8103's Avatar
Ok, a month ago I was thinking this was a u-joint issue. But it seems to come after using 4wd and go after being in 2wd for a while. 4wd operates as I would expect. But after coming out of 4wd, I have this rather pronounced hitch in the steering wheel when turning and I can feel it in the front end. It happens on the gas, coasting, in neutral or not. I've inspected the u-joints and they do not have any tel-tale signs of bad wear or sloppiness. The ball joints are in good shape.
Thoughts?
Old 03-22-2017, 10:28 AM
FMB
FMB's Avatar
Originally Posted by xp8103
. . . after coming out of 4wd, I have this rather pronounced hitch in the steering wheel when turning and I can feel it in the front end.
It sounds like your truck is not coming out of 4wd as you would think.
Back to morning brew . . .
Old 03-22-2017, 02:52 PM
Just a plain ole guy
1-2-3's Avatar
X2 on that thought
Old 03-22-2017, 02:59 PM
xp8103's Avatar
So... Transfer case problem? Back in the day you had a big shifter in the floor that you could manhandle. Now it's all electronic.
Old 03-22-2017, 04:17 PM
Busboy's Avatar
You need to have the front wheels straight ahead and the drive line not "wound up" when engaging and disengaging 4X4, with a manual xfr case you just force the lever but the electronic ones can't do that. I think what you have is considered normal.
Old 03-22-2017, 04:21 PM
xp8103's Avatar
That is my normal operation. I will let of the gas and engage/disengage 4wd. I ended up swinging by my local dealer. The service manager rode with me and suggested u-joints. Said they would need to put it on a lift to properly diagnose. I decided to have them do it Friday. We'll see.
Old 03-23-2017, 07:11 AM
1-2-3's Avatar
I'm never rolling when engaging/disengaging Usually go to park too
Old 03-23-2017, 03:53 PM
SOhappy's Avatar
I put mine in neutral (when I can) when I shift in and out of 4WD, and if it doesn't shift right out right away I'll stop and back up- that always does the trick.
Sounds like to me the OP's 4WD shift solenoid is stuck.
Old 03-24-2017, 06:15 PM
xp8103's Avatar
Right front u-joint. $500, tax and all. What is a $160 "u-joint kit"??? And that took care of the problem.
DODGER BOMBER
07-30-2011 08:30 AM
ristowjim
09-17-2007 10:10 AM
boiler-rat
11-18-2006 02:30 PM
Gordonville
04-18-2005 09:45 AM
Quick Reply: Front end drive issue after 4wd use...
