Really. I just don't have any luck
Received 1,637 Likes
THey were available from the dealer for a while, but not sure now.
It can be welded, you know.... No welding buddies nearby ?
BTW, the way that end is bent inwards leads me to believe that it came out of alignment or was bent by someone, then bent back and snapped. Your FSS wire was disconnected in the process as well.
The hoop should have a spring on the forwards side of it pulling it forwards. If that return spring is / was missing, that could be your cause for the snappage.
I'm sure Ollie has a ton of them....(cables, that is)
mknittle (03-21-2017)
I hope olie jumps n. I'm a welder by trade and was gonna do that if I can't get one. U r right that the spring is missing. I'll be be getting that fixed as well. As for the fss it's still connected just on the other spade. I've had this truck not quite a year and I'm still working the bugs out of it. Thanks for your input
Ollie here jumping in...
I would start by welding it up and getting a spring for it. Then make sure it slides freely.
If that doesn't work, PM me and I will dig up a used OEM spare.
Thanks olie. I'll do that this week. I'll tig it and see how it goes. I got another thread and I'll be makeing a new air horn too. Lord knows I love this truck. Lol
Yeah I just looked at your air horn picture.
There is room for improvement on that, which should be easy to do if your are a welder by trade.
Hey Dan,
While you're at it....
Make sure that bolt / nut / washer combination you have on the front of the pivot that leads to the Injection pump travel rod isn't hitting your kickdown cable.
Looks to me as if when it rotates up, it would wack that kickdown cable, which would explain why it was snapped off.....
mknittle (03-22-2017)
I had the same problem with time. checkout post 1094 here.
https://www.dieseltruckresource.com/...314771/page73/
So I was lazy and decided to jb weld the kick down cable. Guess what. It didn't work so now I'll have to take it off and clean it up and weld it at work. That's what I get for
Taking the easy way out
I have a hard time convening my wife that it may take longer to do it right but you wont have to screw with it twice.
mknittle (03-25-2017)
ratlratl
11-09-2008 10:37 PM
Dodgezilla
47
02-22-2008 10:02 AM
cameroneod
16
10-05-2007 12:36 PM
