How long does your oil stay clean?
Old 05-19-2016, 05:17 AM
KRB
KRB's Avatar
I've run Valvoline Blue for the past 110K and like it fine. It's black as soon as it hits the oil pan...
Old 05-19-2016, 08:45 AM
johnh's Avatar
if clean looking oil is desired, use non detergent oil . personally i wouldn't!!!!!!
Old 05-19-2016, 12:11 PM
Brian.B's Avatar
What helped my motor was when my up seal blew out and pumped a gallon of diesel in the oil......then changed it and oil but didn't loctite the seal so it filled it again after that my oil was beautiful....lol
Old 05-19-2016, 12:48 PM
j_martin's Avatar
There might be quite a bit of variation in engines. specifically ring seal. I've found over the years that when new or just overhauled, as soon as yer sure it isn't going to throw parts at you (about 10 miles) you need to drive it like you stole it to seat the rings. If not they'll always use a little oil or crud the oil up with carbon quickly.
Common sense also that if they smoke, they're going to get more carbon in the oil. The oil is made to hold a fair amount of carbon without damage, but must be changed regularly just for that reason unless extreme filtering (ie centrifugal) is used.
Old 05-20-2016, 03:10 PM
1STGENFARMBOY's Avatar
when i first got my truck my bro-in-law worked at an oil bulk plant, i got a couple 5 gl buckets of oil and did 3 oil changes in a week of driving, then put in the oil of choice and it stayed clean for a few thousand miles, but i pull loads quite often and have some extra fuel now so not very long.
Old 05-23-2016, 11:50 AM
Angry Johnny's Avatar
About 5 minutes.
Old 05-23-2016, 12:21 PM
bannerd's Avatar
Originally Posted by Jim Lane
The old GMC transit coaches I used to work on would slobber out 5 gallons of Delo per 10 hour shift, they had 6-71 Detroit's with over one million miles on them.
Got to love the sound of the detriot.
Brian.B
12-10-2012 02:14 PM
2006BLKMegacab
12-21-2010 12:29 PM
DU.DP.
03-18-2009 12:03 AM
Bobcat698
05-06-2007 08:21 AM
tanderson2002us
10-03-2003 10:48 AM
Quick Reply: How long does your oil stay clean?
