How to replace engine oil cooler, where do I get one??
Old 01-13-2009, 09:06 PM
thewished's Avatar
Exclamation How to replace engine oil cooler, where do I get one??
I need help, I'm pretty sure I have an engine oil cooler leaking. I cannot find one for the life of me and I do not know if I can change it myself or do I have to have a mechanic look at it?
Any help is appreciated!!!!
Old 01-14-2009, 09:18 AM
blackimpala's Avatar
OK it just might be my oldtimers disease but I don't know what an oil cooler is.
I know that we have auto trans coolers but not oil coolers.
Old 01-14-2009, 09:55 AM
infidel's Avatar
It's easy to replace.
The cooler is behind the oil filter.
Drain antifreeze.
Remove the oil filter then remove the the bolts that hold the oil filter housing on and you've got it.
p/n from Cummins for a '97, think they are all the same though
(1)oil cooler gasket- 05003481AA
(2) oil cooler- 04713985
(3)Oil filter head gasket- 04882997
Old 01-14-2009, 11:11 AM
greenrig's Avatar
i wonder if thats this guy's issue. http://sfbay.craigslist.org/scz/cto/991997240.html that would be a steal if so.
Old 01-14-2009, 04:34 PM
infidel's Avatar
i wonder if that's this guy's issue.
That or maybe a head gasket.
That truck looks like it was rode hard and put away wet.
Notice how the rear end sort of sags like it was overloaded a lot.
I sort of get a feeling it wasn't maintained very good either.
Old 01-14-2009, 04:36 PM
lgp9999's Avatar
Good eye... I didn't even notice the sagging! It would take a LOT of abuse to do that to one of our trucks!
I'll bet the Dana 80 held up just fine to all the bumper dragging towing and hauling though!
Old 01-14-2009, 05:55 PM
greenrig's Avatar
maybe he has a load in the bed in the picture? i have never seen this truck even though we live in the same small town. so i'm not trying to sell it but whats a little work and towing going to hurt on our trucks that's not replacable or rebuildable. maybe i'm on last years prices or CA prices for CTD's but this seems like worth checking out. isnt the nv4500 worth half what he is asking?
Old 01-14-2009, 09:15 PM
dozer12216's Avatar
Back to the oil cooler. Different years have bigger coolers. If you buy used, make sure everything is the same. I believe they interchange is you use all the parts. Cooler, plate, correct gskts, and housing from same year.
Old 01-14-2009, 09:21 PM
1997-12v's Avatar
Just get the engine number and call a cummins dealer. Or put the engine # on here and ill tell you what part number you need to get.
Old 01-14-2009, 11:34 PM
1stGen545's Avatar
that's the best way.
also there are 2 diff gaskets that can go between the core and cover so make sure you get the same one you have if you don't get it from Cummins. if you use the wrong one you can have very high or very low oil pressure.
best to just go to cummins but be ready they are not cheep.
You can pressure check the core to see if its good. Do you have any oil in your water. usualy do with bad oil cooler
Old 01-15-2009, 10:09 AM
infidel's Avatar
Almost certain all the 12 valve have the same cooler, they for sure all have the same filter housing.
on edit: Just checked the part number for 94-96 oil coolers is the same as the '97.
Interesting thing is the '94-'96 parts manual says there is a core charge on the cooler.
Old 10-24-2014, 05:57 PM
apprentice's Avatar
This is the thread that came up when i googled oil cooler 1992 12 valve . but your part numbers are different so i will post the inter cooled ve pumped 12 valve oil cooler part numbers. attached quote from cummins with numbers
Attached Thumbnails How to replace engine oil cooler, where do I get one??-screen-shot-2014-10-24-4.49.21-pm.jpg
tyssniffen
08-27-2012 10:41 PM
04ctd
06-14-2008 05:06 AM
dwmcneill
25
05-22-2007 11:29 PM
ratat98
29
08-11-2006 09:41 PM
thumper 549
10-14-2003 11:59 AM
Quick Reply: How to replace engine oil cooler, where do I get one??
