How To Remove The HVAC Box
Old 07-28-2009, 12:14 PM
Jim5870's Avatar
Here are the steps needed to remove your HVAC box from the vehicle
to be able to change your heater and evaporator coils or clean-out
the box.
FROM UNDER THE HOOD
1- Disconnect negative battery cable
2-Disconnect heater hoses at firewall
3-Remove isulation cover from firewall
4-Remove condensation drain tube
5-Evacuate the freon from the AC system
6-Remove Blower Motor
7-Unplug vacuum lines from brake booster and heater shutoff valve
8-Push vacuum line firewall grommet to cab side
9-Remove freon lines and H-block valve
10- remove nuts that hold heater box to firewall
FROM ISIDE THE CAB
11-remove glove box door
12-Remove lower right kick panel
13- Remove fuse block cover, let the fuse block hang down
remove shift indicator tab from column
14- Loosen steering coloumn support nuts to the bottom of the studs
(this makes removing the instrument panel bezel easier)
15- Remove instrument panel bezel and message center display
(removing these parts makes your dash more flexible whe the time comes
to flex the dash)
16- Remove instrument panel display and radio
17- remove ashtray and it's support
18-Remove the heater control unit
19-Remove the ABS control unit
20-Disconnect the temperature blend cable from the heater box
(push in red tab and lift up)
21- Disconnect electrical connections from HVAC box
22- Disconnect vacuum lines from HVAC box (mark the colors)
23- Unscrew and remove the duct vent duct
24- Unscrew and remove the floor delfector
Continued on How To Remove The HVAC Box, PART 2
Old 07-28-2009, 12:36 PM
Jim5870's Avatar
25-Remove the floor air deflector
26-Remove dash brace left side of glove box
27- Remove brace bolts above ashtray support
28- Remove screw above accelerator pedal
29- Remove support screw from right kick panel area
30-Remove right side dash support bolt
31- Pull on right side lower dash, hook support bracket onto door edge
32- Pull heater box away from firewall, lower from under dash while turning
firewall side towards floor. HVAC box should now slide out.
33- Remove top cover screws and lever arms to open HVAC box
34- watch for hidden screws
Continued on How To Remove The HVAC Box, PART 3
Old 07-28-2009, 01:08 PM
Jim5870's Avatar
35- Once you have the top cover removed you can see the evaporator coil and the heater coil along with all the debris.
Here is your heater core
Here is your evaporator coil
36- Take out your coils and then give your HVAC box a good washout with soap and water
37-Here is a shot of the old and new heater cores together
38- Wrap the new heater core with the foam insulator supplied with the core
39- I cleaned the evap core and re-used it. The replacement coils weren't
fitting good. Notice the angle of the new core's ports
40- I flushed my evap core by filling it with laquer thinner, let it sit
about 15 minuites then blowing out with shop air. Did it twice and blew
through both ports. I made a trigger lock for my blowgun and set it
for 40psi. Let i blow down for half an hour to thoroughly dry it out.
41- Replace the flushed coil back into the HVAC box
42- Check that the internal doors work smoothly on their pivots,
dab the hinge pins with grease during re-assembly
43- Re-install the top cover of the HVAC box, if your box does not seal well because of warpage then use some foil tape to seal the warped areas
44- Check the vacuum servos for proper operation.
Re-install HVAC box to vehicle
Old 07-28-2009, 01:35 PM
roxxx's Avatar
nice Geeez i wish u lived closer
Old 07-28-2009, 05:11 PM
sdstriper's Avatar
Like I said in the other thread... Ford Pinto
Old 07-28-2009, 06:35 PM
95ram's Avatar
Good write up. I just did this today.
Old 07-28-2009, 07:45 PM
Onemoparnut's Avatar
I am glad someone did a write up on how to do it with out just cutting a hole in it. I did mine in the beginning of summer and it really wasnt bad at all to get it out.
Old 07-29-2009, 05:20 PM
Merged the three threads together and added a link in the sticky.
Thanks for doing this, Jim!
Old 07-29-2009, 07:24 PM
Jim5870's Avatar
Thanks,
I cut the heater box on my blue work truck to clean out the box,
I couldn't bear to do that to my play truck, did it the hard way instead.
It really isn't that difficult of a job if you know the steps.
For my next trick I'll be changing the intake manifold gaskets
on the wife's chevy 3.1
Old 07-29-2009, 07:27 PM
What about pintos?? my dad has one and its indestructible
Old 01-08-2010, 10:29 AM
GLHS's Avatar
I am going to do this today.
What brand core did you use as I notice the replacement is much thicker or which brand should I use?
Old 01-08-2010, 10:48 AM
Jim5870's Avatar
I got from NAPA
Old 01-08-2010, 11:23 AM
simplysmn's Avatar
Pinto Put In Nickle To Operate
Old 01-08-2010, 11:25 AM
james1's Avatar
Question
It seems you purchased a new evaporator coil and then couldn't use it because the fitment was so poor?
If so, what brand evaporator should we avoid?
Old 01-08-2010, 05:13 PM
Jim5870's Avatar
I think it was "Four Seasons".
I returned the coil, my parts store brought in another and its ports were out of alignment just as bad, so I cleaned out my original and reused it.
Quick Reply: How To Remove The HVAC Box
