My injector swap....
Old 09-18-2014, 08:10 PM
  #46
BearKiller's Avatar
OK I found one...or I should say I was able to get one loose from the injector. Those suckers are darn near welded on!
Remember these were installed and crushed for sealing....but it appears that the thickness was originally .060". OD is an average of .630 +/- .003. And the ID is an average of .375" +/- .002.
Many thanks for taking the time and trouble to get these measurements.
Now I have something to work with; first, I am going to see what McMaster-CARR has.
Old 09-18-2014, 08:58 PM
  #47
Received 1,332 Likes on 862 Posts
No worries. And I didn't have to pull any injectors either...these were the original ones from my 89 motor. So they were already out.
I have one of those copper washer kits....I'll go check to see if any of them would work on the 9mm injector.
Old 09-18-2014, 09:01 PM
  #48
Received 2,394 Likes on 1,577 Posts
I am reading along, as a guy that has a few 9 mm injector style motors in the line up.
Thanks Trashing!
Old 09-18-2014, 11:23 PM
  #49
BearKiller's Avatar
Another idea has been lurking in the dark recesses of my wee skull; I figure the return washers have that connecting strip of copper to facilitate installing them without losing one or both in the process, and it also provides a handy handle to hold them in place while lining things up.
Another oft removed hollow bolt that would also benefit from such an arrangement is the AFC boost-tube banjo fitting.
Old 09-19-2014, 01:59 AM
  #50
KRB
KRB's Avatar
I wish all banjo bolt washers were like that. It would make things a lot easier!
Old 09-19-2014, 04:57 PM
  #51
I open up my pack of replacement copper washers for the 7mm tip motors...ain't no way in that they would work for the 9mm injectors.
Old 10-31-2017, 11:47 PM
  #52
Another one bites the dust.....
Archived...
https://web.archive.org/web/20171101...r-swap-297436/
Old 11-01-2017, 08:43 AM
  #53
bigragu's Avatar
Thank you, TCows! Boy, you're on a mission to save these! Good job!
thrashingcows (11-01-2017)
bigwheels94
07-11-2008 03:10 PM
Treangen
63
07-07-2008 07:42 PM
herb
07-13-2004 04:10 PM
yrusoslow2
01-14-2004 02:38 PM
rattle_rattle
18
11-18-2003 05:22 PM
Quick Reply: My injector swap....
