which plugs in first?
Old 01-28-2008, 10:20 PM
Ceno's Avatar
i have a TST and just got an EZ. The EZ go into the map sensor then the TST into the EZ right?
And on the rail side the EZ to the rail then the Quad rail gauge to the EZ?
Thanks for any help!
Chris
Old 01-29-2008, 12:57 AM
RamWheelsBy4's Avatar
I have mine just the opposit. MAP = TST first then EZ and then OEM. Rail pressure gauge should always plug into the sensor first to see actual sensor readings. Just my .02.
Old 01-29-2008, 05:40 AM
Ceno's Avatar
Thanks man
Chris
Old 01-29-2008, 08:16 AM
rufushusky's Avatar
I did the same thing with my ramifier.
Old 01-29-2008, 11:02 AM
JCLeary's Avatar
If you have an EZ, you want the TST first. The EZ caps boost at 18-21 or so psi, so some TST programs won't fully fuel (this was the case on my '03).
If you have a MP-8, you want it plugged in first as it tells the TST the manifold has more boost than it really does, giving you better bottom-end fueling. You wouldn't run the TST rail pressure settings, though.
Haulin_in_Dixie
01-13-2011 08:03 AM
Bradleysram
19
05-12-2009 08:36 AM
RyeThomas
34
10-13-2008 10:47 AM
TDRattler
08-07-2008 07:10 PM
bigragu
03-19-2006 03:52 PM
Quick Reply: which plugs in first?
