which plugs can I use?
Still working on my auxiliary coolant filtration kit. I have the housing and the filter. My options are to tap into the heater core lines...1 tee on the supply and 1 tee on the return to work as a bypass system. Other than the heater core lines, are there any plugs that I can remove and thread a barbed hose fitting to go to the filter housing and another port to go back to so I can still run bypass? My housing is set up for 3/8" fittings. Carmyne
you can tap in to the heater return for your filter return and if the 93 has a plug by the t stat use it (my 90 has a 3/4 pipe plug there) if you tap in to the heater feed line the filter slows down the coolant to much and you heater will suck in the winter ....I know ,I temp. took my filter off cause of it but i will replumb it later
Totallyrad
Jul 19, 2011 07:41 AM
RyeThomas
34
Oct 13, 2008 10:47 AM
Ceno
Jan 29, 2008 11:02 AM
Greenhornet1986
25
Mar 10, 2006 07:55 AM
