turbo installation help needed
hi there i am replacing the turbo on my 2002 1 ton dually hx35 with another hx35 is it just a straight forward unbolt and bolt back together process or are there things that i am not aware of?
turbo install
hey clutch1 thanks for the reply what is the easiest way to prelube the turbo? i had just planned on filling it with oil via the oil line going into turbo is there a better way?
thanx
thanx
Just spin the compressor while pouring oil into the top where the oil line goes in. Also....sometimes you gotta "clock" the housing to align the intercooler tubes or oil line. Just loosen the bolts on the back of the compressor housing & turn it if you need to & retighten.
92smokin blacky
08-08-2010 11:46 PM
sallyman1
02-08-2009 09:05 PM
Little-bit
10-03-2007 03:19 PM
betsycam
09-09-2004 11:29 AM
Commatoze
03-03-2003 06:48 PM
