Tranny Problems!!
Old 09-16-2009, 08:07 PM
bigg-p's Avatar
Tranny Problems!!
Hello everyone, I have a 2006 dodge ram 3500 crew cab 2wd SRW Auto! The other day I was driving and noticed that when the truck tried to shift into second gear, it felt as if my tranny was slippin!! I could feel the slip and noticed my rpm's going up. Previously, I noticed the truck would act as if it were trying to find 1st or 2nd gear if I were driving at low speeds! I also noticed that it would not do it when was towing, but then again, who drives the same way while towing as they do empty? Can anyone help? The mods that I have are True Flow Filter Pac, M.B.R.P. Cool Duals and had a Diablo Predator that was kept on tow or economy mode! (Removed Several Weeks Ago). Thanks, From North Carolina
Old 09-16-2009, 08:52 PM
TonyB's Avatar
Common problem...Here's the fix: https://www.dieseltruckresource.com/...ht=shift+trans
It's the governor solenoid and pressure transducer that need replacing.
4617210 Solenoid-Trans Gov
56028196AD Tranduce-Pressure Sensor
Tony
Old 09-17-2009, 09:33 AM
bigg-p's Avatar
Thanks TONYB!! It would just happen to go out as my warranty went out (just turned 40K)! Do you remember what the cost was if they printed it out for you and you don't mind me askin? Thanks In Advance. BIGG-P
Old 09-17-2009, 12:57 PM
Mr.mean's Avatar
Worth looking into
I have an 2004.5 48RE auto transmission. I was having the same problem with mine at around 100,000 miles. I took it to the transmission shop and all they had to do was tighten the bands. There is a adjustment set screw or bolt on the left side of the tranny that allows you to tighten the bands when they start to loosen up.
Old 09-17-2009, 05:29 PM
bigg-p's Avatar
Thanks Mr. Mean!! I'll get with my tranny guy and see if he's familiar with it. Thanks Again
Old 09-18-2009, 09:12 AM
TonyB's Avatar
I don't have a cost....Mine was done, just before the warranty ended.
http://dodgeparts.com/
Click on Dodge parts on the right side. IIRC, you can enter part numbers. Their pricing is less than the local dealers.
Tony
Old 09-18-2009, 08:21 PM
bigg-p's Avatar
OK. Thanks for allthe input. I was thinking it was my touque converter, i'm glad i didn't just go out and buy one.
Old 09-18-2009, 08:51 PM
Crude dude's Avatar
I had the same problem at about the same amount of miles. My transmission guy suggested NOT adjusting the front "intermediate" band because the bands in these transmissions are already too thin and any adjustment on it will cause the band material to wear faster due to gripping again and you will soon be buying a forward clutch drum due to metal on metal contact. When I took my trans apart he was exactly right. Usually the clutches are fine and the torque converters are fine with minimal power adders but the front intermediate bands cannot hang in there. Fortunately good aftermarket bands are pretty affordable but then you have to pull the trans and tear it down to replace the band. As for the 1-2 shuttle shift, I installed a Trans-go shift kit in mine and it is still there when the transmission is cold. I will be trying the Allison electronics upgrade soon, I have heard great results from this.
DJ Turbo.
10-13-2011 09:11 PM
Black Dog
12-03-2009 08:18 PM
staken
03-05-2008 07:41 PM
95 Dodge
07-02-2006 03:28 PM
SmokinShaker
23
11-18-2002 09:49 AM
Quick Reply: Tranny Problems!!
