Tranny Cooling Line
Old May 11, 2004 | 09:23 PM
Stamey's Avatar
Question Tranny Cooling Line
I have this part number for a replacement line to the tranny cooler.
Dodge Part # 5011244AA
I want to know if anyone has installed this, and exactly which line it is. I need the line that goes from the tranny to the heat exchanger on the right side of the engine. I'm hoping this is the correct PN for that line, with a fitting built in for a temp sender.
Thanks,
Chris
Old May 11, 2004 | 09:28 PM
phox_mulder's Avatar
Pretty sure that is the right part#.
I had mine installed, and didn't see how or where they installed that.
I know they lost 1 quart of fluid doing it though.
It should be about $106 from Dodge.
Did a quick search, and that # comes up in a bunch of threads about tranny temp.
Here's a thread with a lot of info
(including some posts by you I believe)
https://www.dieseltruckresource.com/...a&pagenumber=2
phox
Old May 11, 2004 | 10:46 PM
billg's Avatar
Chris you got mail.
Old May 11, 2004 | 11:18 PM
Stamey's Avatar
OK, I'll put it on order tomorrow.
Thanks,
Chris
Old May 11, 2004 | 11:21 PM
BigBlue's Avatar
It's really easy to change. I wish I had some pics of where it went. As soon as you get the line and look under the truck, you'll know instantly where it goes.
Old May 12, 2004 | 06:55 AM
Stamey's Avatar
Oh, I know where I hope it goes. BillG's pics confirmed it. I have just been under there trying to fix the connection to the heat exchanger which has decided to leake like a sieve. I slowed it down to a seap, but need to replace the line, I guess. I could see no cracks or burs on either side of the union.
Thanks,
Chris
Old May 12, 2004 | 11:53 AM
billg's Avatar
I almost forgot. I think there is a check valve in the rubber hose part of the line you are ordering. You need to pull it out because there is a check valve in the cooler you are tying into on the side of your truck. There will be too much backpressure for the up-graded trannys.
Old May 13, 2004 | 08:04 PM
Stamey's Avatar
Bill,
There's a rubber hose in the line???????????? I thought this was factory Dodge stuff, to run in the same place I have steel now, with a place for my sending unit. I ordered it though my Dad's shop today. 86 and change. I will pick it up tomorrow and take pics of it.
Chris
Old May 13, 2004 | 08:40 PM
billg's Avatar
There is a small section of hydraulic hose on the end that goes to the cooler. There could be a check valve in there. If you shake the end you will hear it, if it's in there. The end at the transmission is all metal and has a place for the sensor.
Old May 13, 2004 | 08:59 PM
Stamey's Avatar
Oh heck. I now wonder if this is the correct hose again. I don't need one going to the cooler. I need the one going form the tranny, under the engine, and up to the heat exhanger. I thought that's what the pic on your gallery was of.
Chris
Old May 13, 2004 | 09:21 PM
billg's Avatar
Sorry that was my typo, it does go to the heat exchanger. You got the right one. The hydraulic part of the line is only about a foot long. It looks like it is there to absorb vibration. When I put mine in everything fit perfect including the sensor (didn’t need any adapters).
unioncreek
Jun 26, 2013 09:22 AM
F&AM
Sep 21, 2011 02:45 PM
Crimedog
Jan 18, 2005 01:08 PM
ckennedy
Nov 15, 2004 05:35 PM
mopar2ya
Apr 1, 2004 06:42 AM
