track bar needed for a 98 2500 cummins
Old 02-21-2007, 08:05 PM
oldblues's Avatar
Question track bar needed for a 98 2500 cummins
hi all ,
i need a track bar and wandered what u all are using that may be beter than the original and not cost a small fortune .
98 12 v 4x4 cummins no lift kit.
thank you !
Old 02-21-2007, 10:10 PM
somis13's Avatar
these are the best
http://thurenfabrication.com/stocktb.html
Old 02-21-2007, 10:27 PM
TheBigNasty's Avatar
I have the Thuren lift track bar and it is definately worth it. Very reasonably priced too.
Old 02-25-2007, 05:31 AM
kfm61's Avatar
Get a good one, don't buy the low priced ones made in China. While they have a warranty, I'm on my second track bar in 7 months, 10000 miles! i'm getting ready to install a kit that will update it to the late style that eleminates the ball end. If I had know about the Thuren at the time I would have purchased that one.
Old 02-25-2007, 08:33 AM
schoust's Avatar
Guy's dumb question but what signs do you look for for wear in the track bar other than handling issues??
Old 02-25-2007, 10:57 AM
Hemi Dart's Avatar
Originally Posted by oldblues
hi all ,
thank you !
If money is tight, Luke's Link it and get a Polyurethane bushing for the frame end.
Old 02-25-2007, 12:23 PM
1-5-3-6-2-4's Avatar
So why is a Thuren better than the Solid Steel?
Old 02-25-2007, 12:29 PM
Danderson's Avatar
Thumbs up Dss
I had great luck with Darin's stuff. Worked great on the '99.
Old 02-25-2007, 09:18 PM
Hemi Dart's Avatar
Exclamation
1) Less Expensive
2) Easy Bolt-on
3) Way Overbuilt
4) No crappy rubber bushings
Old 02-25-2007, 09:39 PM
Originally Posted by Hemi Dart
1) Less Expensive
2) Easy Bolt-on
3) Way Overbuilt
OK.
1) its marginally cheaper
2) mine was easy bolt on
3) mines way over built
4) "Solid Steel Industries LTD. in conjunction with a chemist and our rubber bushing manufacturer have designed a high quality rubber bushing that is better than the OEM bushings on the 2003 and up Track Bars."
CTD2001
08-22-2009 10:03 PM
Dinner
05-29-2007 02:02 PM
kwillis-a
01-25-2007 09:10 PM
dieselgeek
03-19-2003 09:15 PM
Quick Reply: track bar needed for a 98 2500 cummins
