still a leak
Old Sep 19, 2006 | 10:15 PM
bigreddiesel's Avatar
still a leak
1992 dodge ve pump i have a leak at the throttle shaft a big one. i have replaced the seal and the bushing the shaft was good. my question is how do i stick the bushing in. here is what i did i pressed the old one out. when the old one came out it looked like it was held in by glue. when i put the new one in it went in too easy so i put a very small amount of jb weld on it and them pushed it in. is the the cause of the leak. did i screw up. please help i miss my truck
Old Sep 20, 2006 | 01:14 AM
Fis Teck's Avatar
Your first mistake was tring to fix the pump yourself.I work in a in a fuel shop and see this all the time with out the right tool and know how you can
make a mess. If the bushing is not suported when you take it out and install the new one, you can cause a leak and now you need a new top cover.
Old Sep 20, 2006 | 06:20 PM
Moving this over to 1st gen for more exposure. Several of our members have fixed this leak themselves, hopefully one of them will chime in.
Old Sep 21, 2006 | 03:14 PM
i made a plate with a piece of ready rod through the bushing and tightened it down pulling the bushing out. so that fubared the top cover. it did not crack. it looked like there as glue holding it in. if i need a top cover can i get a part number for that piece. thanks guys
Old Sep 21, 2006 | 03:19 PM
apwatson50's Avatar
I've done 2, the first one was mine and it leaked after the 3200 spring install, the 2nd was just a preventative thing. And I just used a bench vice with sockets to support both sides of the cover.
Old Sep 27, 2006 | 06:52 AM
come on i need some help. there is no one out there that can help me.
Old Sep 27, 2006 | 07:00 AM
G1625S's Avatar
How close to binghamton are you? There's a shop here that can likely get what you need...and I'd be glad to have a look and see of I can help. Sorry I don't have the pump top part #
Old Oct 3, 2006 | 12:32 AM
Fis Teck's Avatar
It is cheaper to bye e used pump on ebay then a new cover.
TireHauler04
22
Oct 11, 2019 04:02 PM
zookeeper
Aug 13, 2011 12:08 PM
abc4yew
Mar 29, 2008 08:37 AM
Bobcat698
18
Oct 22, 2005 12:27 PM
McGyver
Dec 10, 2002 09:37 PM
