P0460 Code
Old 02-17-2004, 12:08 PM
cmckinney's Avatar
P0460 Code
P0460
Fuel Level Unit No Change Over Miles
Was checking my truck to see if I had any codes and this code was set on my PCM. Anyone seen this code before and does this code indicate any failure in the trucks equipment that I can prevent.
The fuel gage worked as usual I did not observe any issues during normal operation.
Also received the generic DTC code P1693.
-CM
Old 02-20-2004, 05:54 AM
Alan_Reagan's Avatar
The fuel level arm in the tank probably hung up or was dirty causing the error to be set. Nothing you can do until it fails, then replace the sending unit.
O.T
09-06-2007 06:10 PM
ramtd02
03-04-2006 11:17 PM
Terraizer
12-14-2005 03:56 PM
Ritler
04-17-2005 04:06 PM
CTD NUT
04-05-2005 04:45 PM
Quick Reply: P0460 Code
