oil pan gasket
Old Jan 31, 2006 | 08:53 AM
StrokeThis2500's Avatar
oil pan gasket
i just droped my truck off this morning my oill pan gasket, power steering box, and right front brake caliper were alll leakin a have the chrysler maximum care up grade warranty should all be covered right. that oil pan gasket is not just a quick job or is it i dont know
Old Jan 31, 2006 | 09:01 AM
Hounddog's Avatar
Never seen one leak on a Cummins.Its NOT a quick job if it is.Engine has to be hosted up at min.to remove it,won't come off engine in frame unless something changed on 3gs..Most common oil on oil pan is from blowby tube(normal)or coming from something else.The caliper is covered by extended service contract as is most powersteering parts.Oil pan gasket covered under the Cummin engine and fuel warranty not service contract.
Old Jan 31, 2006 | 02:24 PM
There Replacing The Power Steering Pump For Me I Heard They Were On Back Order But This Dealer Just So Happen To Have One
Old Jan 31, 2006 | 07:16 PM
DmaxEter's Avatar
On the 3rd Gen you can remove the oil pan without lifting the engine. I guess they allowed enough room. Just drop the pan as low as it will go and reach in and take the oil pump pickup tube off and then you can slide the pan off. Sound easy on paper I know
Old Jan 31, 2006 | 07:22 PM
B.Law's Avatar
I'm about ready to take mine in for a leak as well. Last time I was pressure washing underneath, I noticed a decent leak in the rear main seal area. Fairly wet with oil, and a drip hanging, surprisingly no mess on the driveway from it. Just under 3k on the warranty left, hopefully I will get her in there before it expires...
tex23455
Jul 25, 2007 02:31 AM
bostongsx
Sep 25, 2006 11:25 PM
Common
Aug 24, 2006 06:31 PM
vavtx
Jan 6, 2005 03:36 PM
Diesel-Dan
May 26, 2004 04:42 PM
