48re
Old Jan 30, 2006 | 01:23 AM
HawaiiCTD's Avatar
48re
from what i understand the 48re came out mid 03? is this true?
the truck that i am looking at the sticker codes are
DGB and DG8.
Old Jan 30, 2006 | 01:28 AM
HorseHauler's Avatar
if the build date is on or after 1/1/03 then it is the 48re. If it is the 305/555 engine then it is deffinately the 48re. i had an 03 SO with the 48re in it
Old Jan 30, 2006 | 12:22 PM
vess33's Avatar
According to my brother who is the parts manager at the local Dodge dealership, DG8 is the code for the 48RE trans. I came accross this when I was shopping for a truck. Hope this helps
Old Jan 30, 2006 | 04:09 PM
edonald849's Avatar
I have a 04.5, had the tranny redone by timinva, once he had everything broken down the front end was a48re but the rear of the tranny was 47re, IM timinva, he'll verify this, seems DC used left over parts when putting my truck together, wonder if anyone else has this problem
Old Jan 30, 2006 | 06:18 PM
Timinva's Avatar
DTR Advertiser
Ed, you had the o/d planetary (6 pinion) for a 48re but only 5 o/d frictions. The same as a 47re. I have seen several 48re o/ds now that only have the 5, it is like DC just puts the parts in it that they have laying around. Tim
Old Jan 30, 2006 | 08:20 PM
DHAWK's Avatar
48re
Dg8 Does Not Necessarily Mean 48re It Is A Trans Code But It Just Means Automatic. Looked Up A 03 So Today For A Fella And He Had Same Code And It Was A 47re.
When Dc Came Out With The 03.5 48re They Did Use 6 O/d Frictions And The One-sided 23 Friction Direct Clutch In The O/d Housing. They Sent A Bulletin Out That They Worried The Trans Would Shift Too Harsh Into O/d Because Of The Higher Boost Pressure, Stiffer 3-4 Accum Spring, And The Added Frictionon The O/d Clutch Pack. In 04.5 600 Ctd Truck They Went Back To The 5-friction O/d Clutch Pack. In 05 And Newer, They Have 5-friction O/d Clutch Packs, 10/9 Double Sided Direct Clutch Discs Just Like The 47re. All 48's Used The 6-pinion O/d Planet.
Hope This Helps, Pm Me A Vin And I Can Tell You What The Truck Is.
Ad removed site violation
Old Jan 30, 2006 | 09:25 PM
Dhawk Htstransmissions.com
Ohhhh ok duh, i fully understand now
Old Jan 30, 2006 | 09:48 PM
Betsy II's Avatar
48re
i'm curious, could this be why DC is so unwilling to discuss option of an exhaust brake for the 04.5 48RE? Perhaps there are too many autos out there with a combination of unknown / unacceptable parts?
Just my $0.02 worth.
Roy
Old Jan 30, 2006 | 09:51 PM
srt4brown's Avatar
O/D off-------47re------------------Tow/Haul--------48re Simple enough?????
Old Jan 30, 2006 | 09:54 PM
Not True... so not simple enough... my 48re in my 03 SO had O/D off on it. as do all 03 and early 04 trucks
Old Jan 30, 2006 | 10:12 PM
DHAWK's Avatar
48re
Sorry, I Know I Ramble Too Much. Just Really Trying To Help With Information As Much As I Know And As Much As I Can. I'll Try To Refrain In The Future. Don't Me To Bore You Guys, Just Wanna Help.
Dhawk
Old Jan 30, 2006 | 10:16 PM
the info was much appreciated. where are you from?
Old Jan 30, 2006 | 10:48 PM
bubba33's Avatar
my glove box says DG8 and so does my build sheet.I have 2 firends with 03 that have the same thing with there sticker in glove box and there build sheet.there 2 trucks are SO's and mine is a HO.there build dates were mar and aprial.so i would say its a 48re or at least it is supposed to be.
Old Jan 30, 2006 | 11:11 PM
HawaiiCTD's Avatar
thanks for all of the info guys, really appreciate it.
Old Jan 31, 2006 | 04:11 PM
tonyiii1's Avatar
My performance shop said one way to tell if it is an 47 or 48re is to take it out of OD and get the truck up over 55 mph and let off the "gas". If the torque converter locks and holds your rpms up until you drop to around 45 mph it is a 48re. If it doesn't it is a 47re. Kind of confusing, but so was the rest of this post. I have a 48re and it does this exact thing.
