Going to knock out Oil Pan, Crank Seal and fnt timing cover Gasket tonight......
Oil Pan Gasket, Fnt Crank Seal, and Fnt timing cover.
This will be my virgin run on my friend’s truck for all of these for a 12V. Any pointers from any that have gone before would be helpful. I have head that you can do the pan gasket while in the truck. Just have to lift the motor somewhat. ALSO i know about the KDP. I would like to fix it while i am in there. How and what do i need to do so? Thanks in advance!
Dan "Mudinford" MacDonald
EDIT:
...just saw a thing on the KDP...but that was more of a Rear timing cover R&R due to a KDP expulsion. Is there just a fix for the pin? And what hole is it located in?
The Harmonic balancer doesn’t seem to require a puller to remove. Just 4 bolts? Right? Then i have access to the fnt timing cover and Crank seal? Thanks all again!
EDIT:
You are going to tab it I assume? Either run to Cummins and get a tab, or just make your own out of some thinner metal and a longer bolt. There is a great picture running around here that shows where the tab and KDP are located at. Basically there is a bolt to the side of the pin hole that you put the tab under. The search will tell all about it.
dochawken
Oct 23, 2012 06:56 PM
dieselox
Apr 17, 2011 07:24 PM
Zee
Mar 23, 2010 09:54 PM
Hoss
30
Oct 3, 2006 02:57 PM
Diesel-Dan
May 27, 2004 09:40 AM
