new 05 loud rattle when shutting off
Old 10-03-2005, 11:16 AM
motrapper's Avatar
may be its normal but when i shut it off its way noiser then my 7.3 ever was
and do people put extra dahl fuel filters on these and coolant filters thanks for any info. first dodge
Old 10-03-2005, 11:57 AM
bigblock2stroke's Avatar
Fill in your sig. Do you have a G56 with dual mass flywheel? If so, its a known issue and is normal.
Yes, people put extra fuel filters on (like on big rigs).
I haven't seen any coolant filters yet. Coolant is supposed to be good for 100k anyway.
Old 10-03-2005, 12:08 PM
RustyJC's Avatar
The Cummins B-series is a parent bore engine. You don't have to worry about cavitation inhibitors in the coolant like you did on your 7.3L Ford.
Rusty
Old 10-03-2005, 12:10 PM
motrapper's Avatar
it has the new i believe mercedes trans thanks
Old 10-03-2005, 07:49 PM
whtractor's Avatar
Every dodge does the Loud shut dodwn thing. or try changing spark plugs someone explained why the shut down was so loud and felt like the engin was falling apart, has something to do with the fuel being shut off to the engin
Old 10-03-2005, 11:22 PM
DmaxEter's Avatar
Rusty
The powerjoke is a parent block also. Cylinder block erosion and pitting is a serious problem for all diesel engines. The new extended life coolant helps.
Old 10-04-2005, 02:24 PM
The DMF makes shutdown even worse than it already was because you go through the resonant frequency of the DMF system. The single mass doesn't have that problem inherently because it is a single mass.
Belt squeal on shutdown is also from the high diesel compression ratio stopping the crankshaft faster than a lower compression ratio gasoline engine. Worse on autos because the flywheel on manuals helps absorb (or slow down) the shutdown process.
Old 10-09-2005, 01:28 AM
cberndt454's Avatar
My wifes 05 has the new 6sp and it's pretty noisy shutting down too. You can here it rattle a little at idle in neutral also. Push in the clutch when you turn it off and you won't here it. Not a fix, but it's less annoying. Does anyone know if it will tear anything up shutting down that way? It sounds alot less brutal. Take care, Craig
Bullmoose
01-07-2005 12:43 PM
RowJ
11-29-2004 06:17 PM
RonP
10-03-2004 02:16 AM
popeyesides
09-12-2004 12:21 PM
Dodgezilla
02-06-2003 12:56 AM
Quick Reply: new 05 loud rattle when shutting off
