need help with my apps
Old Oct 24, 2006 | 11:51 PM
raffy's Avatar
I have a 1999 Dodge 5.9 diesel and the accelerator pedal is kicking out, I can let it up and then pump it 1 or 2 times then it kicks back in. The check engine light is also on. I am pretty sure that this is my APPS. Is there anything I can do before spending $400.00 for a new one or could this maybe be something else causing this? I could use any and all help I can get on this.
Raffy
Old Oct 25, 2006 | 06:27 AM
crobtex's Avatar
Read the codes and see what comes up.
When my APPS went bad, I didn't have to pump the pedal, it would come back on by itself after a couple of seconds. Do you have a fuel pressure gage? If you are not getting fuel to the VP44, you may have stall problems. When my last factory pump went bad, the pressure would drop to about 2 psi, but I could pump the pedal and it would come back up.
If you are sure it's the APPS, read this thread and you can find out how to adjust the voltage.
Old Oct 25, 2006 | 09:06 AM
johnh's Avatar
Raffy
i got mine from here
http://www.hoeslidiesel.com/
motomac3
Nov 25, 2007 11:24 PM
BIGBEN
Oct 17, 2007 10:58 AM
silver beast
Sep 14, 2007 03:02 PM
azlineman
Mar 30, 2006 09:29 AM
Jim Coleman
Feb 2, 2005 05:03 PM
