Batteries replaced, does APPS need reset?
Old Oct 15, 2007 | 07:01 AM
BIGBEN's Avatar
I was just wondering if I need to reset my APPS(pedal method) if Ive had the batteries unhooked over night? or will it be fine?
Thanks Ben
Old Oct 15, 2007 | 07:29 AM
DSjockey's Avatar
Yes reset the APPS
Old Oct 15, 2007 | 08:19 AM
johnh's Avatar
no just drive it
Old Oct 15, 2007 | 05:41 PM
slim51015's Avatar
Change one battery at a time. You wont loose any settings.
Old Oct 15, 2007 | 06:20 PM
moparmikej's Avatar
I replaced both at the same time and plumb forgot to reset the A.P.P.S.
This was in the summer and everything has been just fine!
Mike
Old Oct 16, 2007 | 06:17 AM
BIGBEN's Avatar
Very Smart Idea.
Actually, I only put that in the title because it fit easier. I had my altinator rebuilt, so I had to have them both un-hooked at the same trime. I have been driving it with out reseting it. but it feels a little like it did before I reset it last time.
Old Oct 16, 2007 | 02:21 PM
sixb's Avatar
Apps, what is it, and how do you reset it, and what is the pedal method. Thanks.
Old Oct 16, 2007 | 02:58 PM
MikeR's Avatar
The APPS (accellerator pedal position sensor) is a fancy name for the throttle position sensor.
You don't have to reset it after you've had the batteries diconnected, the truck will still run fine. But if you want the ECM to see the correct idle and wide open values, you have to start with the cables disconnected:
Reconnect the battery cables, and turn the key to the on position, but don't start the truck!
Slowly press the pedal all the way to the floor and let off slowly, then turn the key off. Simple as that, you have now reset the APPS.
Old Oct 17, 2007 | 09:28 AM
sixb's Avatar
Thanks mikeR, I replaced my tps this summer.
Old Oct 17, 2007 | 10:58 AM
RowJ's Avatar
Don't forget to let it sit for at least 30 min with batteries disconnected.
Actually...have had better luck waiting about two hrs.
See the procedure under 'Tech Facts' in header... https://www.dieseltruckresource.com/...n&onlynewfaq=1
RJ
supr
18
May 21, 2007 09:29 AM
trex
16
Nov 14, 2005 09:45 AM
Luckycharm1
Sep 4, 2005 04:57 PM
PDXDodge
Jun 2, 2005 02:58 PM
MoreSmoke
Feb 14, 2004 08:51 PM
