Lube points on 2500
Old 04-22-2011, 10:04 AM
James Birdsong's Avatar
Lube points on 2500
I have a 04 2500 4X4. I have searched but can only find two greese zerts at the end of the steering linkage. Is there anywhere else that I can lube without adding/changing parts? Thanks, Jim.
Old 04-22-2011, 11:03 AM
Speedracer3456's Avatar
There is a Zerk on the front drive shaft at the CV joint. You have to have a grease needle to get to it.
Old 04-22-2011, 01:17 PM
Lube points on a 2500
Thanks, I'll look for it.
Old 04-22-2011, 01:41 PM
Danavilla's Avatar
FYI Jim,
That fitting is a real Bi*** for many people, including me.
There are a number of threads on it but most use this pic to help find it.
Old 04-22-2011, 02:00 PM
lube points on a 2500
Hey thanks for the pic. I don't think I would have found it!
Old 04-22-2011, 08:35 PM
rootkit's Avatar
Any other spots?
Old 04-22-2011, 10:14 PM
BADRAM1's Avatar
After having every ball joint and the front & rear driveline fall apart around 50,000 miles i had them replaced w/the heavy duty greasable ones..the mechanic was amazed my front end made it to 50,000 he lost his at 25,000 just make sure if you put them in the lower ball you put a 90° zerk in..
ButchCassidy
12-30-2007 10:02 AM
wreedCTD
43
07-20-2007 11:58 AM
CACalomino
06-01-2007 11:13 PM
bigfish5
03-20-2007 08:17 PM
Almond Pale Ale
17
01-25-2007 08:21 PM
Quick Reply: Lube points on 2500
