Lift Pump ?
Lift Pump ?
Does everyone else's lift pump spit a little fuel out of the priming plunger if you push it a few times? I replaced my rubber return line yesterday because it was ruined and in the process of trying to prime the injector pump, I covered my hand in diesel.
Is that normal? If it's not, could this be a possible cause of poor gas mileage? (~13.5-14mpg)
Thanks guys,
Shawn
Thanks guys,
Shawn
No not normal. You have an O ring in that plunger that is leaking. Probabaly allowing air into the system, but, sorry, not much help on the size of the O-ring, but, it can be replaced. Cheap fix once you know the size, I'm sure someone who knows the size will give you that info shortly. Good luck, KD
i second that it should not leak at all. If youre going to pull it, you might as well put a new one.
Take the advice of infidel, use studs to reinstall. It will save alot of swearing.
2-8mm x 30mm 1.25 pitch and nuts
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
