Is the IP top gasket reusable
Old May 18, 2006 | 07:54 AM
PeytonMaterne's Avatar
I removed the top of my pump in preparation for the 3200 spring, wondering if the gasket can be reused or am I asking for a leak. It wasn't hard to take apart, just a little time consuming. I was surprised at how tiny the tophat piece was! Thanks for warning me about it flying off.
Old May 18, 2006 | 08:48 AM
timb's Avatar
Ive re-used 3 so far without a problem.
Old May 18, 2006 | 01:10 PM
bgilbert's Avatar
Why chance it for just $15. Gasket kit is only $15 and you also get a baggy full of goodies. Replace the o-ring on the throttle shaft too while you have the top off.
Old May 18, 2006 | 07:31 PM
I've had good success reusing them.
Old May 18, 2006 | 08:00 PM
Underpsi's Avatar
i've had mine off a couple times and reused the original. But its better to change it unless you don't mind taking it apart again
Old May 18, 2006 | 09:21 PM
edwinsmith's Avatar
I understand that there's a bushing on the "throttle" shaft that gets worn and can lead to leaking. How hard is it to replace along with an updated seal/gasket kit? I'm eventually wanting to go to biodiesel and I need to do my KDP so I figured I'd do it all in one fell swoop.
Edwin
Wanna, what is the proper name for the "throttle" shaft since diesels don't have throttles?
Old May 19, 2006 | 07:10 AM
bgilbert's Avatar
That's what it's called, throttle shaft. The bushing and the shaft itself can get WORN and need replaced. The shaft will develop a groove. It's been awhile since I replaced one, but from my VE exploded view diagram, it shows two o-rings or one oring and a washer around/over the throttle shaft- wet side of the top cover. Replacement is just a matter of removing the top cover. The bushing isn't much, but a replacement throttle shaft is ~$50. I'd try replacing the oring(s) before a new shaft. Or while it's out, inspect for wear/grooves. Bushing is pressed in/out. I'll be doing this fix soon as my new 91.5's top cover is leaking from the throttle shaft .
Old May 19, 2006 | 08:34 AM
Boatnik's Avatar
Reuse it til it leaks.
Old May 19, 2006 | 01:02 PM
edwinsmith's Avatar
Thanks guys. I was wanting to be proactive and replace the bushing while the pump was apart.
Edwin
1985cucv
Apr 12, 2009 10:32 AM
rementa
Aug 4, 2005 04:41 PM
sweetwaterguy
Aug 1, 2005 01:48 PM
HighTen
Apr 30, 2004 05:27 PM
blafleur
Apr 28, 2004 04:42 PM
