injector pump
injector pump
i have a 90 dodge cummins and the injector pump is leaking in the back. between pump and the back block that mounts to it. is there orings or does anyone have a good break down of the pump thanks.
There is a large sealing ring in there between the hydraulic head and the pump housing. Bosch VE seal kit P/N DGK121, big thanks to BGilbert for the part number. Mine sprung a leak in the exact location about a week ago. Kit was $18.80 at my local diesel pump shop. I have an aftermarket kit too, not as good. The chinese kits don't have all the gaskets the Bosch kit has, they do have the seals, o-rings and banjo washers though. Pump will have to be removed to re-seal it...
Is this what you need?
I cannot believe how many pumps are suddenly springing leaks now.
Jim
Location: Springtown Texas, the land of MILFs and Honeys
Jim,
My guy at the pump shop said he's seeing a huge rash of leaky VE pumps now that we're running ULSD around here. Apparantly, the old seals in these ancient pumps aren't compatible with the stuff. He says new seals are fine though, so after rebuild, there shouldn't be a worry about leaks in the future.
Regards,
Kevin Ayers
Regards,
Kevin Ayers
TJ0993
11-08-2007 10:27 AM
gablekevin
09-19-2006 12:12 AM
jbevly
09-05-2006 03:59 PM
loveturbowine
07-26-2005 05:50 PM
Puke
05-22-2003 12:18 AM
