Help lost spring and retainer
Old Oct 5, 2007 | 09:05 AM
slant6racer's Avatar
Can someone help me I lost my spring and retainer for the top hat while fixing leaky fuel pin.
Old Oct 5, 2007 | 01:01 PM
found spring. Can washer be used in place of retainer?
Old Oct 5, 2007 | 06:40 PM
If it was my truck I'd go to the pump shop and get the right piece.
Old Oct 6, 2007 | 12:07 AM
edwinsmith's Avatar
The retainer is a cup that keeps the spring centered so it doesn't rub on the pin. rubbing bad. Get the right part.
Edwin
Old Oct 6, 2007 | 12:43 AM
Jim Lane's Avatar
Post
Is there any chance you dropped the parts into the pump cavity?
If you were not sure I would at least check with a small rare earth magnet on a wire.
It could cause some damage to the internal parts or cause the governor to malfunction.
Jim
Old Oct 6, 2007 | 05:13 AM
I will check the pump cavity better today. I have checked the ground with metal detector and still nothing. There are no pump shops in my area so I will keep looking.
Old Oct 6, 2007 | 10:55 AM
ofcmarc's Avatar
Look on the frame. I found mine laying on the splash shield between the frame and inner fender.
Old Oct 6, 2007 | 12:53 PM
OK all is good now. I was getting ready to remove intercooler piping for a better look and found it under the pipe on splash shield. Those retainers blend in very well. If I can get back together I will feel alot better.
THANKS!!!
Old Oct 8, 2007 | 01:54 PM
I got it all back together yesterday, with a 3200 spring. Thanks for the help. Yes for those who are wondering the spring is a good upgrade, the truck would stop pulling befor the shift point. Now it pulls all the way.
Old Oct 8, 2007 | 06:34 PM
G1625S's Avatar
Gotta love the spring---glad you get it squared away!
MechatronicEng
Mar 28, 2011 12:41 PM
Diesel_Dawg
Oct 15, 2007 01:22 AM
Patrick Campbell
Jan 2, 2005 10:04 PM
PourinDiesel
Sep 22, 2004 06:23 AM
