Help - Parking Cable Retainer Clip
I am trying to find the parking brake cable retainer clips that holds the parking brake cable into the parking brake lever. See the pic below.
I tried NAPA and they said they could not get them.
Thanks in advance,
C. D. Hunter
Thanks in advance,
C. D. Hunter
1st Generation Admin
Dodge part number ~ 4713 293
NOTE ~ The above part number is from the August, 1992 Dodge part book. Said number may have been superseded since.
Hope this helps.
Hope this helps.
Thanks BC847!!! I will run this P/N by my local Dodge dealer and see what they come up with?
I have looked and looked for those doodads. Mine are long gone and they don't show on the dealers blow-up diagram. Thanks for the P/N! Let us know if it works.
If you are meaning the little gizmos that hold the cable in the lever, new ones come with new cables.
At least every one I have ever installed did.
That little folded flat piece would be a simple task to make.
P/N - 04713293 that BC847 posted is the right critter. They cost $3.37 apiece. So if you want to order some you should do it now, because the person I ordered them from said that once they run out of the ones that are in the parts system they are gone.
A big thank you to all of you that responded to my question!
Woo Hoo!
The search feature gave me the answer!!! Wooo Hoooo!!!!!!!!!
Now to see if the dealer has any clue. I will post my results from here in the over priced, over taxed Northeast.
Mike
Mike
