HELP! - Changed Gov spring - won't start
Old Jul 18, 2008 | 10:31 AM
NotEnufGarage's Avatar
Fixed! - Changed Gov spring - won't start - Fixed!
I changed the governor spring last night and just finished putting everything back together and now the motor won't start no matter how long I crank it.
Where do I start to diagnose this?
I cracked open a couple injector lines and they seem to be getting fuel.
Old Jul 18, 2008 | 11:19 AM
ofcmarc's Avatar
Make sure you indexed the throttle shaft correctly.
Old Jul 18, 2008 | 11:21 AM
PapeCAT's Avatar
yah try starting it with the pedal pressed down...
Old Jul 18, 2008 | 02:52 PM
1tondodge's Avatar
you may have knocked one of the wires going to the fuel shutoff solenoid off. Check those first, towards the backside of the IP
Old Jul 18, 2008 | 05:32 PM
It's one or the other. Done both myself.
Old Jul 18, 2008 | 08:13 PM
I checked the wires and all is good. I can hear the selenoid clicking when the key is turned. I tried with my foot on the pedal and it makes no difference.
Each time I turn it over, I'm getting a puff of black smoke out of the tail pipe. If I press the pedal further, it seems harder to crank. There's a sweet spot with just a little pedal pressure where it seems to crank easiest.
I cracked open the front 3 injector lines and I'm seeing fuel spraying when I crank, in pulses.
I disconnected the grid heater and gave it a shot of ether and it fired for a couple seconds, then died.
What next?
Old Jul 18, 2008 | 09:43 PM
Alwaysworking's Avatar
alwaysonDTR
try gutting the solinoid to see if it's bad, maybe its stuck? even thou it clicks
Old Jul 18, 2008 | 09:57 PM
bgilbert's Avatar
What he said. That's most likely your problem.
Old Jul 18, 2008 | 11:08 PM
I can't seem to find a sticky or picture of the right way to index it. Can anybody point me towards one?
I thought I marked it and put it back where it belonged, but after reading a few posts it looks like it's pretty easy for it to slip a tooth or two when you're reassembling the throttle lever.
Old Jul 19, 2008 | 11:14 AM
The index was at 5:30 and 11:30. I moved it to 4 and 10 and it would start if I held the pedal down 1/4 of the way. I couldn't get enough idle adjustment, so I moved it to 3 and 9 and it started up and idled at 1400. I tried backing off the idle screw but it lost contact with the throttle lever, so I lengthened the throttle connecting rod until I had enough adjustment to get a nice 650 idle.
Thanks for all the help!
As it is now, there's no smoke at idle, so I think I'll turn the smoke screw in just a touch. I've got the fuel pin in at the max setting and I loosened up the star wheel 1/4 turn, give or take. I think I got about 1/16" of additional advance, too. I couldn't get the pump to move any more on my own. Maybe I'll try for a little more with a helper later on.
I've got a couple stop nuts to tighten, then I'll take her for a test drive. I hope to see a big difference. Let's see how she does.
Old Jul 19, 2008 | 12:57 PM
Oh Yeah!
That's what I'm talkin' about.
She rev's easily to 3400 off the line. More power, no smoke at all. Guess I need to turn up the smoke screw and full power screw a little more!
Old Jul 19, 2008 | 03:30 PM
PapeCAT's Avatar
sounds great! Hope you have the 60lb valve springs...
Old Jul 19, 2008 | 08:33 PM
From what I've read, they're not really needed until about 3600 RPM. Hope that's right.
Old Jul 20, 2008 | 07:14 AM
According to Cummins the stock springs will handle a 50% overspeed without allowing the valves to contact the pistons.
mattzram
Oct 9, 2006 11:38 AM
fishin fever
Mar 13, 2006 06:46 PM
fitzydog
Apr 21, 2005 09:04 PM
dominojd
Jun 21, 2003 01:24 AM
99purplecummins
Dec 7, 2002 10:38 AM
