Getting Headlights off
Old 01-23-2008, 06:15 PM
97 D-Tec's Avatar
Does anyone know or have any suggestions on how to get the headlights off .. i only see 2 bolts.. are there more on the bottom? do i have to take the front bumper off or loosen it?
Old 01-23-2008, 06:57 PM
TXaggie09's Avatar
if its the same as my 01, there are 3 screws if i remember right, I had to drop the bumper down a few inches. Once you get the bolts off, the lights should pop out with a little bit of effort.
Old 01-23-2008, 08:11 PM
Doj Dewd's Avatar
there are three screws/bolts which hold it to the fender. the piece attached to the fender is the mount only. the headlight & parklight are attached to the mount via adjusting screws.
if you wish to take it off as a whole assembly then remove the bumper cap and save yourself some headaches. be careful removing the cap, it is very easy to break the plastic clips/retainers.
you can probably remove the light housings by popping off the adjustment retaining clips then sliding them out, and then the mount afterwards. this can probably be done without removing the bumper cap as it creates smaller pieces rather than one large object.
why are you removing headlights?
Old 01-23-2008, 08:27 PM
mopar-or-no-car's Avatar
You can remove them without doing anything to the bumper, I have numerous times. There are three screw/bolts that hold them in.
Old 01-23-2008, 08:46 PM
fordkiller43's Avatar
As everyone else said there are 3 bolts. Good luck!
Old 01-23-2008, 09:06 PM
97 D-Tec's Avatar
im putting in new 1 piece headlights
Old 01-23-2008, 09:50 PM
Doj Dewd's Avatar
i also installed the clear one piece, they really made a difference in looks and functionality. if you don't have them in yet, i would recommend running a bead of silicone around the edges. . .
i did it for peace of mind, not because i had any problems with leaks. . .
Old 01-23-2008, 09:51 PM
Doj Dewd's Avatar
. . . also, get some super glue or other adhesive to attach the dust gaurds to the new headlights before installing.
M Penwald
03-26-2011 08:41 PM
tool
03-16-2005 12:31 PM
Rocketman
10-25-2004 10:04 PM
TurboTed
02-01-2004 09:13 PM
Scubasteve
03-03-2003 07:00 PM
Quick Reply: Getting Headlights off
