fuel pin
Old Jun 5, 2007 | 10:08 AM
dagrizz's Avatar
fuel pin
new to sight, so hello to all ...ive been thinking of ordering the bully dog fuel pin, but im not sure on how to install it , does any one have instructions? or diagrams? any help will be greatly appreciated thank you..
Old Jun 5, 2007 | 10:18 AM
Cowboy_Customs's Avatar
Welcome to DTR! And save your money!! Search for "old smokey" or "ol smokey" if you r even somewhat mechanically inclined u can do the mod yourself, and save 200 dollars for other things. All it takes is maybe an hour, n a dremel tool. Its very easy to get at it, Im assuming u have a Pyro installed? I dont recommend this mod w/o one. let alone much else either, but every truck responds differently to the mods. The old smokey fuel pin typically nets an extra 100* EGT. (same for the bully dog pin) they just make one then jack the price a mile high.
Old Jun 5, 2007 | 10:27 AM
oh, sorry, the pin is under the AFC top. looking at the pump u see a cover with 4 flathead screws and a round cap in the middle, (the smoke screw adjustment is under that cap) remove the 4 screws, and the boost line on the back side of the top your about to remove, i think its 12 or 14 MM, watch out for the 2 copper washers! once thats all removed, pull the top off, now u will see a rubber diaphram, pull that out, thats the fuel pin. Note there is a deep side, and shallow side. Stock, the shallow side will be facing to the front of the truck. You can either replace the whole pin with an aftermarket one, cut it to an old smokey pin, or just simply turn the pin so the deep side is facing toward the front of the truck. Then reinstall everything. There is a nylon washer, just slide it onto the pin n slide it back into the spring.
Also, when u pull the pin u will see a star wheel in there. This sets the tension on just how much boost is required to start the pin in its travel downward. Adjust it to your liking, this basically determines just how long it'll take before u reach full fuel.
Old Jun 5, 2007 | 01:34 PM
LOGAN's Avatar
Muted User
thanks cowboy, thats the clearest explanation ive gotten to do it, ill probably do it this weekend.
Old Jun 5, 2007 | 02:02 PM
You r very welcome, dont we have a sticky on this?
Old Jun 5, 2007 | 02:55 PM
dagrizz's Avatar
perfect thank you much, sat i will pull it out and try this...
do u have any pics? thank you again
Old Jun 5, 2007 | 03:01 PM
90firstgen's Avatar
If you don't want to grind the pin, then PM Old Smoky right here on this site. He's the original manufacturer/researcher of the fuel pin. The bullydog is a knock off and also costs more. Old Smoky's price is $124 now if you PM him.
Old Jun 5, 2007 | 03:06 PM
LOGAN's Avatar
Muted User
PDR has the fuel pin for 175$ but you get 100 of that back after sending hem your old fuel pin, so they cost 75 bucks. www.piersdieselresearch.com
Old Jun 6, 2007 | 05:29 AM
Jim Lane's Avatar
Check down on Part-3 first image is of the AFC housing.
The fuel pin is item #41.
Also please fill in your signature so we can serve you better.
Jim
https://www.dieseltruckresource.com/...d.php?t=153154
Old Jun 8, 2007 | 10:56 AM
dagrizz's Avatar
re fuel pin
hey thanks again for all the much needed info... so i did it the other night and yeah baby now she's smokin... also did a custom air intake last night for about $120, now she's a pullin
gaberichison
Dec 21, 2014 12:21 PM
Cowboy_Customs
Oct 18, 2011 01:46 AM
West Coast
May 26, 2007 10:22 PM
bigragu
Oct 17, 2005 04:07 PM
Crimedog
Mar 11, 2004 01:54 PM
