Fan Noise
Old 08-25-2003, 04:10 PM
brillmtb's Avatar
Fan Noise
Does anyone else but me feel the fan is louder than the engine? Seems that clutch fan is very noisy until something happens like it disengages or something. Its a wind noise I dont think anything is wrong with it but it doubles the noise overall.
Old 08-25-2003, 04:42 PM
Thats MR Hoss to you buddy!
Hoss's Avatar
Re:Fan Noise
Yes.
Old 08-25-2003, 06:07 PM
spots's Avatar
Re:Fan Noise
Sounds just like a big gasser don't it? You could always trade down to an '02 so you don't hear the fan.
Old 08-25-2003, 07:50 PM
mymaur's Avatar
Re:Fan Noise
Does make alot of fan noise. But either I have gotten used to it, or it is quieter after 11,000 miles. I actually believe it seems to tone down with break in time.
2 cents
Old 08-25-2003, 08:05 PM
mitchkim's Avatar
Re:Fan Noise
yes the fan is noisy but look at what it has to cool
1 a/c condenseer
2 intercooler
3 radiator for a 305 hp 550 tq engine
4 transmission cooler to carry 20000lbs wt
5 power steering cooler
i would rather hear the fan than see steam coming out from under the hood
Old 08-25-2003, 10:14 PM
Gunship Guy's Avatar
Re:Fan Noise
I can't hear my fan due to the loud noise coming out of my tailpipe (no muffler!).
Old 08-26-2003, 02:32 AM
SuperGewl's Avatar
Re:Fan Noise
If your fan is too noisey all the time then turn off the AC and it will stop . It should stop when you get enough air flow accross the radiator when moving. 8) 8)
If your makes it all the time take it to the shop and have them fix it.
Old 08-26-2003, 08:16 AM
Hoss's Avatar
Re:Fan Noise
Every time that fan comes on I find myself applying the brakes to keep my truck from running away like an airplane...
Old 08-26-2003, 08:35 AM
KenR's Avatar
Re:Fan Noise
The roar (sound) of the fan is normal but if the "Duration" of that roar is excessive then you have a problem. If it doesn't stop by the 1st shift (auto) or near that shift then the "Fan" might need to be replaced. Mine was replaced due to the long duration, up to over 30mph, and my problem was solved.
Good luck.
Old 08-26-2003, 02:06 PM
brillmtb's Avatar
Re:Fan Noise
I think my fan stays fast and loud beyone 1st gear but I will check
Old 08-26-2003, 02:17 PM
Hoss's Avatar
Re:Fan Noise
When mine comes on, it typically shuts off right after I've shifted into 2nd......or I guess it's really third because I start out in 2nd.
Old 08-26-2003, 02:26 PM
KenR's Avatar
Re:Fan Noise
Go here to read about my experience with the Fan Roar. Read the entie thread.
http://www.dodge-diesel.org/yabbse/i...8422#msg138422
My problem is no more. It was solved and I enjoy my truck more.
NJTman
09-05-2012 12:05 AM
jrs_dodge_diesel
09-28-2007 11:38 AM
MmmDieselFumes
09-27-2007 06:44 PM
MmmDieselFumes
09-27-2007 03:04 PM
big jimmy
07-07-2006 01:33 PM
Quick Reply: Fan Noise
