Factory Cruise Never Has Worked, How to Diagnose?
Old Jul 11, 2008 | 11:14 PM
keith1992's Avatar
Figured this would be in the sticky, but didn't find anything. My factory cruise control has never worked and I don't know squat about cruise control systems other than the names of the components and everything does seem to be present and connected. So where do I start with the diagnostics?
Old Jul 11, 2008 | 11:22 PM
PDW Power's Avatar
I've worked on a cruise control unit on a 96' 12v and visual inspection it looked fine but the cruise operates on a vacuum one of the lines was just old and cracked but not completely broken. I'm not sure if its any different for a 1st gen. if it is the same it's a fairly easy fix.
Old Jul 11, 2008 | 11:43 PM
If your horn doesnt work then its your clock spring in the steering column stoppin the cruise from workin.....and check fuses too.
Old Jul 12, 2008 | 06:26 AM
The switches on the steering wheel and the clock spring are the two most common trouble spots.
Check the switches first, they are easiest to check.
Old Jul 12, 2008 | 11:39 AM
apwatson50's Avatar
The clock spring can still be bad even if the horn does work. The horn has the largest contact through the clock spring so the rest of the contacts can break and the horn will still be good. You really just need to test the continuity of all wires going through the clock spring. The FSM has a really good section on diagnosis of the CC.
Old Jul 12, 2008 | 06:29 PM
archer39's Avatar
what do you have to do in order to check the switch?
Old Jul 12, 2008 | 06:33 PM
Pull off the horn cover so you can unplug them from the clock spring.
Old Jul 12, 2008 | 08:21 PM
keith1992's Avatar
Horn and everything else on the steering wheel works fine. No crunching sound either.
How does the horn cover come off? I am not feeling any screws on the underside...
Old Jul 12, 2008 | 08:23 PM
They are there, just tucked way up in the wheel.
Old Jul 12, 2008 | 11:20 PM
grandpa ralph's Avatar
For me, it was the brake light switch.
It's real easy to check, just twist yourself under the drivers side dash. Follow the brake pedal arm up and you will see a small metal switch box with one button coming out. That needs to make contact with the brake pedal arm. If this doesn't make contact, the cruise thinks you are stepping on the brakes and it wont work.
good luck.
Old Jul 13, 2008 | 04:13 AM
Jim Lane's Avatar
Would anyone happen to have a good copy of this to share?
Jim
Old Jul 13, 2008 | 08:21 AM
apwatson50's Avatar
Jim
I don't have an electronic copy, all i've got is the complete FSM "bible" version from geno's and no way to scan the pages. It would be nice if someone had an electronic version of the entire FSM!!
sorry, Aaron
Old Jul 13, 2008 | 04:03 PM
unixcowboy's Avatar
Give me some time...I just got mine...
I hate hard copy, so hard to find cross references....
iweb
27
Jun 13, 2007 07:57 AM
GCSS
Aug 14, 2006 12:29 AM
redneckonthenet
Feb 28, 2005 10:01 AM
mymaur
Jan 14, 2003 08:29 PM
Tackdriver
Jan 9, 2003 06:11 PM
