Help me diagnose cruise control not working
Old Aug 10, 2006 | 09:37 PM
GCSS's Avatar
Question Help me diagnose cruise control not working
My CC doesn't work. I hit the button on the steering wheel and no light comes on in the dashpanel.
No cruise functioning at all.
I went through the fusebox,and all fuses appear to be OK.
There is NO fuse designated for cruise either.
I went under the hood and checked that fusebox and still everything APPEARS to be OK.
How do I systematically check this out?
I have a 1998 12 valve quadcab dually with a 5 speed.
I love the truck,but jeeps...gotta have cruise!!!
Your suggestions welcome!!
Dave
Old Aug 10, 2006 | 10:34 PM
timeagain's Avatar
ooPh
You Have No Vacum,, Check out your pump!! or lines!!
Old Aug 10, 2006 | 11:11 PM
waldersha's Avatar
I guess another possibility could be your clockspring. Do you hear any noise when you turn the wheel from lock to lock?
Old Aug 10, 2006 | 11:55 PM
Double A's Avatar
There is no light on the dash, but there is one on the switch panel on the steering wheel. Vacuum wouldnt affect the light coming on- that sounds like a lack of power flow.
Pull the switch out- there are two screws from underneath the steering wheel that allow it to come out, then get out a multi-meter and start checking for power and ground. Or, go to the dealer and just get a new switch panel. I think mine was about $50? That was with my shop discount, but they shouldnt be much more than that at retail.
Old Aug 11, 2006 | 09:38 AM
infidel's Avatar
Best bet is to buy the Diagnostic Manual for your truck here
www.techauthority.com/
They cost under $15 and have over 50 pages of step by step procedures on diagnosing the cruise control alone.
Otherwise you can end up needlessly throwing parts at the problem.
Old Aug 11, 2006 | 11:16 AM
GCSS's Avatar
There won't be a light on the steering wheel....that's for the older models. This truck is a 98 the year they went to the new interior design.
(Same as the 2001 I used to have)
The 2001 light came on in the dash.
I was thinking it is an electrical problem....namely the on/off switch on the steering wheel.
I was hoping to check a fuse,but don't know which circuit it is on.
Old Aug 11, 2006 | 11:17 AM
GCSS's Avatar
No noises in the wheel.
Turn signals work fine.
Old Aug 11, 2006 | 03:16 PM
garretch's Avatar
i found the battery leaked acid on the pump/valve under the drivers battery box which ate the vacume hose a bit. replace hose problem fixed.
Old Aug 11, 2006 | 10:17 PM
GCSS's Avatar
would that make the light on the dash not go on?????
Old Aug 12, 2006 | 03:54 PM
garretch's Avatar
i had no light till i fixed the vacume line.
i have a 95 and there is no light on the steering wheel, just on the dash
Old Aug 13, 2006 | 10:05 PM
DRam11's Avatar
Vacuum lines and lights: I've had to replace vacuum lines several times now and have never seen lack of vaccum affect the indicator light. If memory serves correctly when my switch stopped working I removed it and cleaned all connections with electrical contact cleaner. It's still working a few years later. It seems that on another forum the comment was made that the clockspring and/or switch was a weak point in 199x model Dodges. Double A is on the right path - check electricals.
It wouldn't hurt to check the vacuum, but it doesn't sound like that's the problem. On my '97 the line that breaks most often is the one that runs from the vacuum pump to the firewall. I finally replaced the plastic line with a rubber line. Maybe that'll last longer.
Old Aug 13, 2006 | 10:37 PM
infidel's Avatar
You sure?
Neither of my '95s have a light in either place, there has never been a cruise light anywhere.
Old Aug 14, 2006 | 12:29 AM
garretch's Avatar
doh! youre right! ...it must have been my other truck
GCSS
25
Mar 19, 2017 03:31 PM
ouchman
Oct 30, 2011 01:35 PM
NoSparkplugs
May 25, 2007 02:42 PM
NoSparkplugs
Oct 16, 2006 10:59 PM
perk
Jul 2, 2004 06:00 PM
