Exhaust housing porting
Old Aug 13, 2007 | 11:09 PM
Dodge5.9's Avatar
Here is my question. I have my old 12cm w/g housing laying around and I'm thinking about porting it. I'm thinking about removing some of the flow divider and drill out my waste gate hole and the divider to around 3/4". Any thoughts? Here is my thing, if I mess it up or it cracks I'm not out anything so why not. If I did these things and installed it in place of my 16nwg would my egt's at power be highed or lower? If anyone has done this some more info would be great either pro's or con's.
Thanks,
Adam
Old Aug 13, 2007 | 11:13 PM
rockjeep73's Avatar
I say go for it. EGT shoudlnt change much between the two, but it will spool a lot quicker and sooner and you will be able to adjust your boost.
Old Aug 13, 2007 | 11:15 PM
Dodge5.9's Avatar
Thats what I'm thinking. Also has anyone removed the whole flow divider?
Old Aug 13, 2007 | 11:31 PM
rockjeep73's Avatar
Check out the last picture on the first page of this thread...
https://www.dieseltruckresource.com/...rted+wastegate
Old Aug 13, 2007 | 11:40 PM
rbrettctd's Avatar
Check this one out.
https://www.dieseltruckresource.com/...289#post555289
Old Aug 13, 2007 | 11:41 PM
Dodge5.9's Avatar
Hmm, looks like it can be done then.
Old Aug 13, 2007 | 11:58 PM
rockjeep73's Avatar
Heres what I did with mine...
https://www.dieseltruckresource.com/...ight=wastegate
Old Aug 14, 2007 | 01:39 PM
Dodge5.9's Avatar
Sounds good, that might be my plan for this weekend
Old Aug 14, 2007 | 02:25 PM
HOHN's Avatar
I just gasket matched my inlet and carved on the outlet a bunch. I drilled the housing divider by sticking a bit through teh WG hole and enlarging the hole in the divider to match the WG hole.
I also enlarged the WG hole itself to where it was as big as I felt I could go and still have the flapper seal it.
Result was no loss in spoolup, but a 75-100 degrees EGT under some conditions.
jh
Old Aug 14, 2007 | 08:15 PM
Dodge5.9's Avatar
cool, thanks for all the info.
MikeThomas
Mar 9, 2007 07:14 AM
SuperiorRam
Feb 17, 2007 05:40 PM
caleb c.
Jan 13, 2007 05:16 PM
Bobcat698
Nov 8, 2006 11:20 AM
TheBigNasty
Nov 5, 2006 02:51 PM
