BD aux pump?
Old 08-14-2007, 12:57 PM
natew05's Avatar
BD aux pump?
What does anyone know about the BD auxilary pump for the fuel system? is it worth anything and what is its cost compared to fass 150
Old 08-14-2007, 01:09 PM
dodgezilla04's Avatar
i have been running one for 2 years. supports over 500 on my rig
Old 08-14-2007, 03:35 PM
natew05's Avatar
what about cost ?????
Old 08-14-2007, 03:53 PM
mx684's Avatar
i have a bd on mine....i took mine and had it done at a shop because i was too busy to do it myself at the time i needed it...costed me only 370...has been working great!
Old 08-14-2007, 04:15 PM
i paid about $230 at the time, and installed myself. its really easy to do.
iforge03's Avatar
i had one on mine, but i got tired of replacing the factory lift pump that i ran in line with the bd pump. the last time i had fuel pressure issues, i got tired of testing to find out which pump went out and just got the fass 150.
Old 08-14-2007, 04:18 PM
i am only running the bd pump. at normal levels pressure at cp3 inlet is 13(with a 7 micron filter) and at WOT with everything maxed out 50psi boost, it goes to 11psi. good little pump.
Old 08-14-2007, 08:31 PM
Carp's Avatar
The BD pump only puts out 100gph so you cant compare it to a Fass 150, compare price with Fass 95. The BD aux is a great pump. It is quiet and reliable. The install is easy and well laid out in the enclosed instructions. BD has a tech line if you get in a pickle. They stand behind the product that they sell. The fuel filter housing can get air locked during the install, giving a hard start at first, but if you jumper the pump and loosen the filter cap, the problem goes away. If you want a lot of responses to your thread, just put "lift pump" in the title. Good Luck.
cp177
09-29-2006 10:42 PM
hotdram
01-31-2006 10:14 PM
Txwelder
12-26-2005 08:45 AM
N.Johnson
05-26-2005 10:50 PM
caleb c.
04-22-2005 06:24 PM
Quick Reply: BD aux pump?
