Poor Mans Aux Fuel Pump ?'s
Old Sep 17, 2006 | 09:22 PM
cp177's Avatar
I work at an auto recycler and have access to numerous types of frame mounted pumps. My question is; what is the max pressure I can run with my stock LP, and has anyone got any other ideas.
I am not ready to spend 300-400 dollars just yet, because I want to upgrade to an 03-up CTD.
Old Sep 17, 2006 | 10:16 PM
cat1713's Avatar
Go with the Carter " campaign " pump it will cost you 70 bucks and will fit in the stock position. But, I would definetly go to Genos garage and get the relocation kit because you will not like the pressure you get in the stock position. I seen some guys running up to 30psi but that that's with a dual LP set up. I got my pump at an International dealer.
Old Sep 18, 2006 | 09:21 PM
longdude's Avatar
I read somewhere that the in-line lift pump used on the 6.5 liter G.M. diesels makes a good aux. lift pump, but why not use it as a primary lift pump, bypassing the block mounted Carter? I drove a chevy diesel for years and never had a lift pump go bad, every thing else, but not the lift pump.
Old Sep 25, 2006 | 06:07 AM
cp177's Avatar
Went with the 6.5 GM pump. Just went down in the yard and got a couple of fuel filter fittings from an 88-94 GM gas truck.
I cut a section out of the old line and spliced in the the pump. The sticker on the pump said 10-15 psi max, so that should be sufficent to keep my vp alive incase the LP dies.
I don't have a fuel pressure guage yet but will try to have one this week.
Thanks for the help guys..
Old Sep 25, 2006 | 12:13 PM
piperca's Avatar
I'd check the pressure ASAP! Just because it says 10-15 psi doesn't mean that's all your going to get!
Old Sep 25, 2006 | 11:03 PM
longdude's Avatar
Let us know how this works out for you. I have been thinking of doing this myself. You are not the the only poor man on the site.
Old Sep 26, 2006 | 12:19 AM
ProspectorTim's Avatar
Originally Posted by cp177
..that should be sufficent to keep my vp alive incase the LP dies..
The main reason for the "campaign" pump was the fact that when the LP fails, it restricts flow. The campaign pump has been redesigned to NOT restrict flow when it fails; and the kit includes a low-pressure sending unit.
Old Sep 26, 2006 | 06:14 AM
cp177's Avatar
Gallons Per Hour:32
Pressure Rating:10-15
Pump seems to be doing fine. My drive to work is 65 miles one way, so I had a little time to play around. Didn't notice any real power increases. Truck has better throttle response on the upper range and I might have gained 1mpg by doing this .
Old Sep 29, 2006 | 10:42 PM
pquevill's Avatar
I used the Geno's relocation kit and you may want to try the Aeromotive AE11203. It is on my veggie side and runs 16psi at idle, 12 psi at 65 mph and never below 10psi at WOT. When my relocated campaign pump fails, I'll add the aeromotive to the diesel side. Really nice pump for $165 at summit Racing or any other local speed shop.
Q
Stew130
28
Jun 24, 2009 10:59 PM
alborada
May 4, 2007 11:43 PM
dieselJon
Mar 20, 2007 06:48 PM
65fury
17
Mar 9, 2007 08:38 AM
DieselDaze
Jul 29, 2004 08:45 PM
