Poor mans Bhaf cover
I wanted to see how it would run with the bhaf installed so I got rushed and did not build/install the bhaf mount yet. I used some double sided electrical tape to build up the bhaf (three wraps) so it would fit the stock intake hose better and hopefully keep it from falling off. The only water proof material I could find was some corrugated plastic and a bungee cord
BTW I towed about 10,00 pounds 50 miles yesterday and could not tell a difference but I still have stock pump settings
so I did not expect to see much difference but I thought It would sound different but id did not, guess my straight pipe is just to loud to tell
use what works... i went to a local fab shop that i have done welding for... cost me 45 canadian 18 for the alluminum and a 1/4 hr labour charge but it looks pro.i was gonna do the stock pot thing but then lazziness set in.
I sucked in a piece of tape and it destroyed my HTT stage 3 impeller.
Just go to the parts store and buy a 5" hose clamp. Mine hasn't moved since then.
On could take a short piece (~6") of 4" exhaust pipe, stuff it into the filter so the end is flush with the end of the lip, and glue or screw it to the BHAF lip. That way, you dont have to worry about tape falling off, or getting stuff sucked into the impellar.
In my experience, electrical tape tends to slide to the place of least resistance.
Daniel
Daniel
This is the correct way to do it. The BHAF was designed to be clamped onto a pipe, not to have a hose clamped over it.
Stew130
28
Jun 24, 2009 10:59 PM
dieselJon
Mar 20, 2007 06:48 PM
, the hose is on there real tight and the tape is on the outside of the filter "neck" and sticky on both sides It would have to really have some suction to get it loose I think, but I guess anything is possible. I will be getting some elbows and the mount soon I hope.
