A different Boost gauge, The Poor Mans Gauge
Old Mar 20, 2007 | 03:02 PM
dieselJon's Avatar
Lightbulb A different Boost gauge, The Poor Mans Gauge
Could I use a oil pressure gauge as a effective boost gauge?? I was thinking a electronic send/analog dial setup. The only thing that would seem different is the symbol/words of oil. They both operate on the same principle and If I get a oil gauge with actual numbers I think it might work.
Has anyone done this, and if so, how did it work? Thanks
dieseljon
Old Mar 20, 2007 | 03:09 PM
bgilbert's Avatar
Yep, pressure is pressure. I don't know about the electric thing, but I've used boost gauges to read fuel pressure, oil pressure to read this, that etc.
Old Mar 20, 2007 | 03:24 PM
andyr354's Avatar
I even used a $5 water pressure gauge from the hardware store for a while.
Check out
www.surpluscenter.com for some cheap gauges
Old Mar 20, 2007 | 05:15 PM
EClancy's Avatar
hmmm, i like this idea. where does one tap for a boost guage?
Old Mar 20, 2007 | 05:17 PM
andyr354's Avatar
no tapping required. There are a pair of unused ports with 1/8" pipe plugs in them towards the front of the intake manifold, above the injection pump.
Andy
Old Mar 20, 2007 | 05:32 PM
Check out
What he said. They usually have gauges in the correct range for around $10. As long as you don't mind that the gauge says "Water"...
My fuel pressure gauge is a water pressure gauge.
Old Mar 20, 2007 | 06:48 PM
BearKiller's Avatar
Andy
Also, directly underneath the air-intake horn is an eighth-inch plug.
Stew130
28
Jun 24, 2009 10:59 PM
alborada
May 4, 2007 11:43 PM
65fury
17
Mar 9, 2007 08:38 AM
cp177
Sep 29, 2006 10:42 PM
DieselDaze
Jul 29, 2004 08:45 PM
