Modified HX-35 wastegate
Old Feb 21, 2006 | 12:34 AM
rockjeep73's Avatar
Well today I finished modifying the internal wastegate on my hx35 12cm housing. I used the info and pictures that were provided by got...DIESEL? except that I didnt go with as large of a hole and flapper. The stock wastegate hole is 3/4" or 19mm, which has a surface area of 283.5sq.mm. I opened the hole up to 1" or 25.4mm, which has a surface area of 506.7sq.mm. So basically I was able to enlarge the surface area of the wastegate opening by 44%, if my math is correct. The flapper that I made is 1 5/16" in diameter which is the largest that I could fit in the housing without machining it. It also required no modifying or removal of the stock flapper arm or linkage. I just had to grind off the stock flapper and weld the new one in place. Another thing that I did in order to allow the flapper to open farther is that I ground a notch into the backing plate of the turbo where the flap makes contact with it. I also removed the divider in the housing all the way down to the back of the wastegate hole and radiused the path to the wastegate hole in an effort to smooth out the flow. Let me know what you think.
Cory
Stock flapper over new one
Old Feb 21, 2006 | 01:02 AM
Artsi_L's Avatar
78% increase in cross section.
Good job.
[edit]
BTW, top two frames are a touch dark. Easy matter to edit them.
Open pics up in a Windows photo editor. Click 'Picture' tab in the toolbar, choose 'Balance'. Move 'Gamma' slide to right one notch, and enjoy.
This way I can make even most underexposed pictures much better.
Old Feb 21, 2006 | 06:35 AM
SHARPMACHINE's Avatar
Great write up, thanks for sharing. Please tell us what you see for egt reduction and performance gains.
thanks
Old Feb 21, 2006 | 12:59 PM
rockjeep73's Avatar
I will post results as soon as I get the head back on the motor and get the thing on the road again.
Old Feb 21, 2006 | 04:10 PM
Very nice!
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
dodgeman01
14
Feb 14, 2003 12:13 AM
mxboy
Dec 7, 2002 12:36 AM
