How do I remove fin sensor in the evaporator
Old 06-17-2009, 06:18 PM
thomasg's Avatar
I have an '03 and the A/C has been freezing up and want to move the fin sensor in the evaporator. I cut a hole in the HVAC housing and can get my hand on the fin sensor but it won't just pull out. Is there a trick to it or do I have to get access the back of the evaporator? Also does anyone have the part number of the fin sensor.
Thank you in advance
Thomasg
Old 06-17-2009, 06:55 PM
C Schomer's Avatar
It's a freezestat and it should cut off the compressor if it gets cold enough. Some of them have a wire that hooks around the evap. tube. Craig
Old 06-17-2009, 09:23 PM
Just a plain ole guy
1-2-3's Avatar
If it's freezing it's probably low on freon. It's suppose to be where it is.
Old 06-17-2009, 09:54 PM
thomasg's Avatar
Its not low on freon. in '03 dodge put the sensor in the wrong position,
Old 06-17-2009, 10:05 PM
dezeldog's Avatar
Mine is freezing up as well. Where is the correct place for the fin sensor to be?? TIA
jim
Old 06-18-2009, 07:08 AM
SAVOY1964's Avatar
This is all i could find in the manual it mentions instructions but could not find them you can see the sensor looks to be pushed onto the fins.
Old 06-19-2009, 12:09 AM
han solo's Avatar
I also have a 03, does the same thing. Ratlratl on here works @ a dodge dealership. He told me, just put it in the center of the evap, as it near one corner. Said no parts had to be purchased thou. Im dreading pulling apart the dash.
Old 06-19-2009, 02:38 PM
Peterbilt's Avatar
I think there is a tsb addressing this problem.
Pete
Old 06-20-2009, 05:30 PM
han solo's Avatar
I had couple of people tell there is a tsb, but I can never find it. Looked thru all the tsb that geno's garage lists. Maybe somebody will put a link or something.
Old 06-20-2009, 10:58 PM
bob4x4's Avatar
No tsb ...this is the star recomendation
Replace the evaporator temperature sensor with part number 5140727AA. Relocate the new sensor to the upper right hand corner of the evaporator. The distances are taken from the air exit side of the core, with the top denoted as positioned in vehicle. 5 5/8 inches (143mm) from the outside LEFT plate (this corresponds with the 12th fin column from the left) 2 inches (51mm) from the TOP of the plates (not the top of the tank).
Old 06-21-2009, 08:55 AM
thomasg's Avatar
Thanks Bob4x4 Thats the info i was looking for.
Thomasg
rjweiss
06-01-2013 04:59 AM
annabelle
06-28-2010 08:42 AM
snakefarmer
08-13-2008 04:18 PM
kully560
17
08-18-2005 03:14 AM
Quick Reply: How do I remove fin sensor in the evaporator
