Dealerships and High Idle Function
Old Dec 11, 2007 | 05:25 PM
MRFD715's Avatar
Have a quick question, does anyone know a dealer in North Iowa that knows (and I mean actually knows) what they are talking about when it comes to Dodge Cummins trucks. I went to my local dealer today, Ebert's in Charles City, to get the high idle enabled in my truck, they tried to tell me that it didn't even exist until 3rd gen trucks. After ten minutes of arguing with the head technician I walked out. There has to be a dealership around that can help me out. Thanks.
Old Dec 11, 2007 | 05:40 PM
Doj Dewd's Avatar
there is a tsb on it. find that number and take it back to the dealer. i think you can find it on geno's.
Old Dec 11, 2007 | 06:40 PM
waam's Avatar
Lest we forget
High Idle
Mine is on a faster Idle all the time. Dodge dealer that works on my truck moved the idle up two yr's. ago. He said they got a TSB from cummins, and they recommended a little faster idle in the winter, and that was to keep the oil up at a warmer temperature, so the valve guides would'nt get gumbed up. waam Holland, Mich.
Old Dec 11, 2007 | 08:27 PM
LUKE-MM-PULLER's Avatar
I tried out a smarty, and low and behold the first time it got below 20deg the high idle kicked on. and then when it got to 0 degrees it went to 3 cyl idle.
Old Dec 12, 2007 | 12:39 AM
mopar-or-no-car's Avatar
So the smarty gives you three cylinder high idle and regular high idle?
Old Dec 12, 2007 | 06:55 AM
bentwings's Avatar
Mine did and I love it.
Old Dec 12, 2007 | 12:07 PM
graphitecumnz's Avatar
Yes. All softwares that Smarty has include high idle and 3 cylinder high idle.
So for the original poster... if you want to skip dealerships all together, find someone local with a Smarty, load in a software, then load in the stock software and you'll have high idle enabled.
Old Dec 12, 2007 | 12:51 PM
dssimecek's Avatar
I don't think you can get the "HI Idle" enable that is set with the cruise control when it is cold. But the dealer should be able to put in the "3 cylinder enable."
It is TSB18-019-1. When it is cold it will run on 3 cylinders for faster warm up.
Old Dec 12, 2007 | 09:33 PM
robert78.5's Avatar
Had 01 done at local dealer and it has both high idle and higher 3 cyl idle, works great, all you do is start truck and walk away. no cruise to push or anything.
Old Dec 12, 2007 | 10:01 PM
mx684's Avatar
im getting ready to setup my own high idle, from the flip of a switch in the cab ill be able to idle it up to any rpm (under 1550) that i desire....i was looking into having the dealer enable it, but you wont be able to turn it on when you want, so for the $20 sum dollars worth of parts and wiring, im going to go this route.
Old Dec 12, 2007 | 10:27 PM
bob4x4's Avatar
It may set a code...........
Bob
Old Dec 12, 2007 | 11:08 PM
mx684's Avatar
i found some guys that have done it, i found all the diagrams and parts lists and instructions in a past thread...they all claim it works flawlesly....
atch
Nov 1, 2010 02:45 PM
LooseBoltsRob
39
Sep 25, 2008 08:43 PM
na4now
24
Feb 15, 2008 02:52 PM
MTC
15
Dec 3, 2006 03:39 PM
skchevota
52
Nov 25, 2006 07:45 PM
