Clutch, No Clutch?
Old 12-07-2008, 08:58 PM
big wally's Avatar
Clutch, No Clutch?
2002, 5 speed, 2wd.
97,000 miles
The truck runs great, but every once in a while, limp clutch pedal?
Pump it, back to normal?
What could it be?
No loss of fluid?
Master cylinder, on the clutch, is the only thing I can think of.
Thanks, in advance.
Old 12-08-2008, 02:50 PM
dozer12216's Avatar
Hyd clutch assy is failing. Recomend replace as one piece assy from Dodge. Can get a aftermarket from Southbend clutch with slightlly larger cylinder for a few bucks more. Don't try replacing just one piece. Hard to bleed and may get wrong part. JMHO
Old 12-08-2008, 06:28 PM
big wally's Avatar
Clutch
Dozer, is this an internal part?
I was going to replace the master cylinder and the slave, all exposed.
Thanks.
Old 12-09-2008, 07:36 AM
drafalske's Avatar
He's talking about the master/slave combo that Dodge sells. You get the master, slave, reservoir, plumbing... all pre-bled and ready to go. It's about $200 from Dodge. South Bend Clutch sells a similar combo for a little more money.
Dave
Old 12-09-2008, 07:48 PM
big wally's Avatar
Clutch, No Clutch
Thanks guys, I will go with the combo.
A little more expensive, here in the great white north.
Will let you know what happens.
Old 12-09-2008, 09:33 PM
Tate's Avatar
Call Harry at Peak Diesel, he will have the Southbend parts. I bet he will be less than what the Dealer will be.
WACTD
07-25-2006 11:41 AM
Fishbait
06-06-2006 12:34 PM
mbmrang
01-21-2006 12:49 PM
kwhite4
05-09-2005 03:22 PM
Quick Reply: Clutch, No Clutch?
