click/click/no start 97 4x4
Old Jun 22, 2006 | 08:30 PM
MBman's Avatar
Ok so lots of clicks with turn of key,nothing, then it will turn over and start. not consistent, but intermitent,
starter??
Old Jun 22, 2006 | 08:36 PM
marksmith's Avatar
Sounds to me like you might be a candidate for starter contacts.
Do a search for starter contacts and I'm sure you'll come up with where to find them
Old Jun 22, 2006 | 08:54 PM
jimk's Avatar
no starting
starter??
I use to have a Toyato turbo diesel that had the same type of starter, it uses the same contacts in the starter. I replaced the contacts on the toyato with some that were a lot bigger in 86 or 87, the toyato was a 85. I had the same problems with my 95 dodge. Along with the starter relay that also would also cause the clicking. I have also seen the brushes worn out on my father old dodge cause no starts.
If you have good batterys, good conections, check the relay, the contacts, finally the brushs. That may not be the problem, but it is a place to start looking. If you have a volt meter perhaps you could check for voltage drops. good luck Jim
Old Jun 22, 2006 | 10:01 PM
TurbineWhine's Avatar
I would put money on the starter solenoid contacts. You will probably find one worn completely away and the other will look brand new. If this is the problem, you should get it fixed soon, because this can lead to the starter hanging up in run mode, which can lead to a burned fuel shutoff solenoid. Those are about $225. The contacts are cheap and easy to put in once the starter is removed.
TW
Old Jun 23, 2006 | 10:59 AM
bamadzl's Avatar
Here's another vote for the starter contacts. I was having the same problem and ordered some of LarryB's starter contacts. I did the job in about 2 hours start to finish this past Monday night. You can see a pic of the old and new contacts in my gallery.
Brad
Old Jun 23, 2006 | 10:52 PM
Hammily's Avatar
The place to go
I just ordered new starter contacts from Larry B http://www.fostertruck.com/dodge/default.htm
John
Old Jun 23, 2006 | 11:14 PM
BKoserDiesel's Avatar
battery ends
Just had the same problem with mine only I need battery ends. It could be the contacts too.
Old Jun 23, 2006 | 11:25 PM
durasmack's Avatar
Get the Foster Truck contacts. Even if that is not the main problem, it will help. Unless the batterys are weak or loose, that sounds like its your problem.
Old Jun 26, 2006 | 07:46 AM
MBman's Avatar
thanks everyone, I am looking at the starter contacts today
Old Jun 26, 2006 | 08:35 AM
MBman's Avatar
can the selinoid part be replaced and will this take care of the contact issue?
Old Jun 26, 2006 | 05:25 PM
plow's Avatar
the fuel shutdown selenoid hardly ever goes bad 95% of the time the rubber boot is torn on the selenoid letting dust and crime get in and gum it up all they need is a new boot lubed up and put back on. Your problem sounds like your starter contacts and they will evetually get bad enough to make the starter stick and will ruin the selenoid, starter contacts 36.00, new fuel shutdown selenoid around 200.00
Old Jun 28, 2006 | 08:55 PM
MBman's Avatar
starter was toast, I replaced it, all is well except for the dang blasted ABS and brake light that will not go out
marksmith
Aug 17, 2007 02:57 AM
Sleigher
Mar 23, 2007 12:23 PM
cheapskate
19
Dec 27, 2006 08:05 PM
PaulDaisy
Dec 2, 2006 12:36 PM
bnold
Apr 25, 2006 06:57 PM
